| 92 gmc dies when put into gear I have a 92 GMC 1500, with a 305, 179,000 miles This al started, i was driving, pulled up to a light, and died, wouldnt start, no fuel. Replaced the fuel pump, and filter, and i seemed to run fine. about 2 weeks later it started doing it again. i have replaced the fuel pump twice, the filter, both injectors, pressure regulator, idle air control motor. it starts and idles fine, but as soon as i put it in gear, the fuel shuts off ( watched the fuel spray stop). and it then will not start at all unless you dump gas into the carb (prime) . then it will idle fine till i put it into gear. im at a total loss what to do now. any help appreciated Last edited by kjack; 12-06-2008 at 04:12 PM. |
| welcome to the forum Have you tried a scan? sounds like a sensor is weak and not giving the ecm a signal. How long do you let it idle (is it warmed up) before putting in gear?
| Gear problem | yotamuddin88 | Toyota Truck Forum | 11 | 10-05-2007 02:19 PM |
| gear help | joey40949 | Chevy Truck Forum | 18 | 08-18-2007 10:22 AM |
| Gear Oil ?'s | HIUPCHEVY11 | Chevy Truck Forum | 1 | 03-13-2007 05:32 PM |
| Z71 Re-Gear | YngPiggyZ71 | GMC Truck Forum | 1 | 01-28-2006 10:37 AM |
| Gear Ratio??? | Billy2001Z71 | Chevy Truck Forum | 4 | 06-19-2005 02:27 PM |
