| Full Member Join Date: Nov 2008 Location: CA
| Cold Heat? When I have the heater on in my truck, the heat gets cold when I'm at an idle.... but when I am moving it is hot again.... any ideas? it is a 00 GMC Sierra 1500 2wd 4.3 thanks
__________________ Horse Power Sells Cars....Torque Wins Races..... |
| Do the hoses going to the heater cool off at idle? how is the coolant level?
| I will have to feel them and get back to you... the coolant looks to be just right.... if they did cool off, what could the problem be?
| Could be poor coolant flow, when was the t-stat changed last and how old is the water pump, could also just need the heater core flushed. |
| I just bought the truck, so I have no idea... it has 150k on it....
| I would replace the t-stat and do a complete flush 1st. The water pump would be the last option. What is your temp gauge reding? |
| If the heater hoses are cool and radiator hot its a core problem. if all is cool then, go with kennys idea of changing the thermostat. By the way why do you need heat in sunny california?
| its not so sunny out here right now... its about 60 outside...and when you factor in the windchill its about 55.... thanks a lot guys!
| If its 55 here I'm driving with the windows down! |
| well that worked! thanks a lot!
| Its cold in WI and cold in my TRUCK!! HELP! | B-Series | Mazda Truck Forum | 6 | 12-11-2008 02:27 PM |
| Heat won't shut off and is too HOT??? | Indiana GMC | GMC Truck Forum | 21 | 03-27-2008 02:58 PM |
| No Heat, Need Help | johnny05lars | GMC Truck Forum | 1 | 11-17-2007 07:44 AM |
| Help with heat | mitch289 | Chevy Truck Forum | 3 | 11-11-2007 05:23 PM |
| No Heat !! | mattymax | Nissan Truck Forum | 1 | 12-07-2006 09:31 AM |
