Old 12-22-2008, 03:35 PM   #11
Ninja_Lawn_Guy's Avatar
Ninja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the rough
Smile
Ok boss....I'll figure out what I'm gonna do and get back with ya well before then,,OK? thanks again
Ninja_Lawn_Guy is offline   Reply With Quote
Old 12-27-2008, 11:20 AM   #12
Got it scanned a mile from home
Thanx to those who offered help....got it scanned near home.
the codes are:
c0267 pump motor short or open circuit
c0268 same as above
c0291 ecbm failed signal bcm
so...is this common or something I can check?
let me know....I'd really appreciate it.
Old 12-27-2008, 12:23 PM   #13
couldn't find anything for the 3rd code
CIRCUIT DESCRIPTION
The pump motor circuit is integral to the Brake Pressure Modulator Valve (BPMV) . The Electronic Brake Control Module (EBCM) microprocessor energizes the relay within the EBCM in order to supply the battery voltage to the high side of the pump motor. The EBCM microprocessor grounds the low side of the pump motor when activation of the pump motor is required.
CONDITIONS FOR SETTING DTC C0267
  • The EBCM internal relay is on
  • The pump motor is off
  • Low voltage is present from the low side of the pump motor when high voltage is expected
CONDITIONS FOR SETTING DTC C0268
  • Vehicle speed is 13 km/h (8 mph)
  • The pump motor is commanded ON and then OFF
  • High voltage exists from the low side of the pump motor for 100 me when the voltage is expected to be low
ACTION TAKEN WHEN THE DTC SETS
  • The ABS indicator lamp turns on
  • The ABS disables
DTCs C0267/C0268 are ignition latched DTCs, which indicates that the above actions remain true until the ignition switch is turned to OFF (even if the cause of the DTC is intermittent).
CONDITIONS FOR CLEARING THE DTC
  • Repair the conditions responsible for setting the DTC
  • Use the Scan Tool Clear DTCs function
DIAGNOSTIC AIDS
The pump motor is integral with the BPMV. Do not service the pump motor separately. A poor power/ground connection at the 2-way EBCM connector or the 2-way motor harness from the EBCM to the pump motor can cause a DTC C0267. A seized pump motor, shorted pump motor windings or a poor power/ground at the 2-way EBCM connector can cause a DTC C0268. Replace the EBCM or the BPMV if the following tests show that the pump motor EBCM internal circuits have failed.
Important:</B> Reset the J 39200 test leads to zero prior to making any resistance measurements. Refer to the J 39200 in the user's manual.
TEST DESCRIPTION
The numbers below refer to the steps in the diagnostic table:
  1. This step checks for an open pump motor circuit. The pump motor circuit resistance should not be above the 0.3 ohms. Reset the J 39200 test leads to zero prior to making this low resistance measurement.
  1. This step determines the resistance of the EBCM ground circuit.
  1. This step determines the ignition voltage available to the EBCM.
odd-abs-light-service-brake-system-message-abscode.gif  odd-abs-light-service-brake-system-message-abscode2.gif  odd-abs-light-service-brake-system-message-abscode3.gif
i'd rather be hunting
Old 12-27-2008, 12:31 PM   #14
Sounds like french to me bud
I get the process but it's not really something I think I can do...
just under experienced....The 3rd was a bad signal between EBCM and BCM<-(Body control module?)
Old 12-27-2008, 12:59 PM   #15
check your 60 amp maxi fuse to start with, could be a simple fix like that.
Old 12-27-2008, 03:25 PM   #16
I started with checking the plugs and wires leading to the pump and found a half-out plug soaked and filthy with splash dirt. Anyway, pulled it out and the truck played jinglebells one last time, both lights...I blew it out, cleaned the connectors....pushed it back in til it snapped....lights went off, haven't come back yet. "HOPEFULLY" that was the issue.
Thanks for your help mudseeker, I'll be back with future updates on this BS , I mean, situation.
Old 12-28-2008, 07:20 PM   #17
didn't stop coming on...they must not have cleared them, or it's not fixed
probably not fixed
Old 12-28-2008, 10:08 PM   #18
it may take a couple of drive cycles for the code to clear itself. or you could unhook the battery for awhile and let the computer relearn.
Old 12-31-2008, 10:09 AM   #19
Quick update..
I went ahead and checked ALL the electrical connections and drained the old fluid, disconnected the battery for a half hour and it went off...stayed off for 2 drive cycles then came back on....now its on and off...crazy...the maxi fuse was fine, the MC sensor was loose but it clicked in place again. Just a strange set of circumstances I guess.
Or the pump is just on it's way out and sending the codes randomly.
Old 02-12-2009, 03:06 PM   #20
Angry
WELL FRIENDS IT'S BACK AGAIN......Has been off for 2 weeks and today it's back....W T F?
Tags
abs, abs codes, abs light, c0267, c0268, c0291
2003 Chevy question about "service" message jdman Chevy Truck Forum 2 08-16-2008 09:30 PM
Brake service light jarhead2001 Chevy Truck Forum 5 03-22-2008 06:37 PM
2005 4WD Service Light 1Rudeman GMC Truck Forum 3 11-02-2007 06:47 PM
service 4wd message in message center Steve Jordan Introductions 5 05-10-2007 01:00 PM
SERVICE 4WD Message REDSIERRA GMC Truck Forum 1 02-22-2006 12:54 PM
