| Full Member Join Date: Dec 2008 Location: Troy MI
| bad wobble 40mph to 47mph when driving my truck normal it will sometimes wobble at 40mph or so. sometimes it is bad other times it is hardly noticeable. i was told i may need a front u-joint. but just want to make sure. 91gmc 3500 4x4 dump with 76k thanks |
| Banned Join Date: Nov 2008
| Is it a side to side wobble or just a vibration? |
| the steering wheel moves from left to rights bad so i would say a side to side wobble |
| It might be a U-Joint, but I would lean more towards tires out of balance. Have the tires and suspension been checked out recently? |
| the tires have not been checked out. i will have to get them looked at. thanks |
| Junior Member Join Date: Dec 2008 Location: Columbus, OH
| well my boss's dump truck has the same problem and he checked out the tires and suspension and hubs and bearings and nothing looked back then i layed under it while he turned the wheel while it was in park but running and i noticed that the frame rail was moving side to side with the steering... not saying thats your problem but i would do the same thing and see what is moving that shouldn't also put it up on a lift and try to move the tires with your hands if there is play in the tire something steering or suspension is bad. you can usually see. i dont think it would be a u joint because if you in 2wd that front driveshaft shoulnt turn.
__________________ 1987 GMC Sierra Classic 1500 (350 throttle body injection) 1988 Izuzu Pickup (2.3L 2 barrel carb) R.I.P. |
| if evertyhing is tight i would suspect a belt shift in the tire
| I'm dealing with the same thing im thinking since my truck is 15 years young and I have never replaced my front brake rotors or turned them that I would buy new ones. Well my son was going to give me money so I said so that I can get it im going to have him buy them along with the front calipers BUT he just told me today dad I have to pay off some of my account to charge them and some girl owes me $200.00 dollars so I can't right now WELL that means it's not going to happen I can bet my life on it. Hey sorry for hi-******* the thread but im up-set guys you know what im talking about here or the problem with him. OK so when I went over to my buddies house for X-Mas I jack up the truck side per side and moved the tire around checking to see if it was my bearings were loose but it all checked out I even had my buddies son look under the truck while I moved the tire around but I don't think he looked to good. Good luck! GMC PS-Keep us posted and so will I. |
| steering stabilizer maybe ball joints |
| The dreaded death wobble | ultranet | Dodge Truck Forum | 9 | 09-28-2006 10:26 AM |
| 99 Ram 1500 all new parts same old death wobble? | MOPARts | Dodge Truck Forum | 8 | 12-18-2005 11:36 PM |
