| Full Member Join Date: Sep 2008
| 1983 GMC C3500 Catalytic Converter Is a catalytic converter required in CA on a 1983 GMC C3500? |
| somebody on here had to get tested ona 76 3/4 ton, but being a one ton could be different, although i think they usually group the 3/4 an 1 tons together....you can get high flow cats alot cheaper now....
| check your state dmv for inspection requirements online.....ny has it all on the web, maybe ca does to In ny the break point is 9000#'s
| Banned Join Date: Nov 2008
| So then, Can you tell if the truck ever had a cat on it? is there a shield on the floorboard? is the sticker still under the hood that shows the original polution setup? The dealer may be able to run the vin and tell you what stock is. AIR,EGR,CAT,lean run w/sealed carb etc.
| 00 gmc catalytic converter bypass? | smylesM04 | GMC Truck Forum | 8 | 12-02-2008 12:50 PM |
| Catalytic converter question | Nold Dog | Chevy Truck Forum | 5 | 11-26-2008 02:46 PM |
| What are some signs of a clogged catalytic converter? | scott92law | Chevy Truck Forum | 15 | 11-11-2008 11:29 PM |
| catalytic converter for an 02 Avanlanche | Airforce wrench | Chevy Truck Forum | 9 | 06-01-2008 06:43 PM |
| Catalytic Converter | PickUpGirl787 | Chevy Truck Forum | 6 | 01-10-2008 08:57 PM |
