| | #11 |
| Junior Member Join Date: Jan 2009
| Thanks for the diagram pic. I've printed it off for my mechanic. For parts, I managed to acquire a solid bottom end and now am just lining everything up for the top end. And we'll have to do something for the exhaust too. Here's a top end kit I am considering: Edelbrock 2098 Power Package Kit I want to do this project within reasonable budget, so I'm not sure if $1700 on a top end kit alone is worth it. I just need a nice intake and carbs, so maybe we'll just pick and choose each part rather than get a kit like this. The vision is to ideally reach 450 hp with lot's of torque on the low to mid range. |
| | #12 |
| i don't mean to rain on your parade , but if you start making the kind of hp things are going to brake 4x4 or not , so plan on beefing up the drive train , still think you'd be better off with fi . shd |
| | #13 |
| Senior Member Join Date: Jun 2008 Location: kentucky
| I rebuilt a 1977 350 carburated and put it in a 1989 k1500 4x4. It ran good until the transfer case went out. I still have that engine and will reuse it someday I am sure. The only problem I had was slight. I had to get a fuel regulator to decrease the fuel pressure from the electronic intank fuel pump. Of course I did away with all the Emission stuff.
__________________ MY first truck was a FORD.......I've owned Chevy's ever since. 1995 K2500 4x4 5.7L Cheyenne 1991 T-10 Blazer 4.3L Tahoe Package 2000 Ford Taurus - Spouses |
| | #14 |
| For the exhaust, would you recommend a manifold or headers ? We're wondering if headers would fit on this 4x4 truck ? |
| | #15 |
| | #16 |
| Okay here is my tentative parts list and estimated prices. Your constructive criticism, comments, and recommendations are appreciated ! Carb: Holley 04778c. KS Autostores - 04778C Holley Carburetor, Model 4150, 700 cfm, Square Bore, Manual Choke, 4-Barrel, Dual Inlet, Dichromate holley 04778c - Google Product Search $550 The intake: Professional Parts 52031 "Hurricane" Professional Products 52031 SB Chevy Hurricane Manifold Satin $150 Lifters: Competition Cams 85816 Pro Magnum Lifters http://autoparts.cardomain.com/auto-...rs---set-of-16 $99 Camshaft: Comp Cams 122503 XTREME ENERGY HYDRAULIC FLAT TAPPET CAMSHAFT Speedy Car Parts - Auto Parts and Accessories Catalog - Camshaft - Comp Cams 1968 Chevrolet K20 Suburban $140 Rocker arms: Comp Cams 141216 http://autoparts.cardomain.com/auto-...ms---set-of-16 $175 Flowtech Glasspack muffler x2 Flowtech 50250FLT Red Hot Glasspack Muffler $25 Exhaust headers: Edelbrock 68012 Edelbrock 68012 - Edelbrock TES Tubular Exhaust System Headers - summitracing.com $600 In addition we'll need: water pump, air cleaner, pushrods, a high flow oil pump, some tires and probably a bunch of other things I'm forgetting. Found a killer deal on an even better block today so things are going smooth so far. My mechanic friend is pretty ballzy he evidently wants to try and push this thing to 600 HP. I was like buddy there is no way, but he seems confident we can get well into the 500's so we'll see. Let me know if you have any more tips or recomendations. |
| | #17 |
| The Power Plus Hurricane intake from Professional Products is a single plane 360 degree design that provides power in the 3000 to 7500 rpm range. It's an ideal manifold for drag racing or short track racing and its port are very specifically positioned to provide the optimum starting point for custom porting the intake seems kind of overkill to me. any particular reason you have decided on this style?? a good victor jr. single plane intake will do everything that you want plus some. |
| | #18 |
| Senior Member Join Date: Oct 2008 Location: orland park ill.
| welcome! i have no idea how to do what you want but welcome anyways and good luck |
| | #19 | |
This is a good point. It is after all only a half ton. The last thing I want to do is bend the frame on the first day. | |
| | #20 |
| this looks good . http://cgi.ebay.com/ebaymotors/SBC-S...QQcmdZViewItem or http://cgi.ebay.com/ebaymotors/SBC-S...QQcmdZViewItem and be careful which heads use as the intake bolt patern changed after 1986 . shd Last edited by silverhairdeere; 01-14-2009 at 10:37 PM. |
| Carburetor or Fuel Injection | mikejr1226 | Polls | 48 | 10-27-2008 07:57 AM |
| Fuel Injection to Carb Conversion | rehjr0219 | Chevy Truck Forum | 3 | 09-17-2008 11:58 PM |
| Fuel Injection Help!!!! | jud75 | Chevy Truck Forum | 3 | 09-02-2008 12:09 PM |
| Fuel Injection question | junior3382 | General Truck Forum | 5 | 01-21-2008 09:44 PM |
| fuel injection problems | redlightning | GMC Truck Forum | 1 | 09-13-2006 06:28 PM |
