| Full Member Join Date: Jan 2009
| radiator I have a big hole in my radiator and was wondering about any quick fixes. I dont have the money right now to buy a new or used radiator but will when i do. Just need something to get it back on the road for awhile. |
| this all boils down to how big of a hole. if this is something too big for bars stop leak, try using quiksteel. comes in a tube that you cut. knead it together to start the chemical process and put it on. it WILL hold together. |
| Welcome to the forum you can pull the tube and solder the tank hole
| Senior Member Join Date: May 2007 Location: Illinois
| Bradrhale is right, that quiksteel is great stuff... depending on the size of the hole. I used it on a few spots on my 4 wheeler and it takes the abuse. Just make sure the surface is good and clean before you use it.
__________________ |
| Brad and Leo are correct you can have those lines by passed or plugged up and it should be fine if you don't block too many lines. |
| Its only 3 lines and they are pretty good sizes holes. I had a friend of mine tell me to use jb weld but that guy likes to half *** everything so I wanted other opinions. thanks for all the tips. |
| JB weld is a good product and have had several projects work out as long as you use the correct product. can you solder the holes?
| If I had a soldering iron I would |
| | #9 | |
the radiator is not going to costs you an arm and leg. why not go ahead and get a new one with a warranty and never worry about it again?? the soldering idea is a great idea for long term use. i dont think a soldering gun will do much good for repairing large holes though. imagine they were referring to using a soldering torch. | |
| Sorry I thought he understood, a propane torch at least
| Radiator | 93Sierra | GMC Truck Forum | 21 | 11-29-2008 03:05 PM |
| radiator leak | stelmadl | Chevy Truck Forum | 25 | 08-31-2008 10:39 AM |
| Radiator fan | dogsrme | GMC Truck Forum | 4 | 08-16-2007 09:38 AM |
| oil in radiator??? | s-dimeblaze-her | Chevy Truck Forum | 9 | 09-16-2006 08:37 AM |
| radiator | fatboi | Chevy Truck Forum | 7 | 09-15-2006 07:20 PM |
