Old 01-24-2009, 09:15 PM   #1
batty1214's Avatar
how do I get a reader to work
I have a 1995 GMC k1500 sierra with a 5.0, that has a random miss..... I have replaced the plugs, wires, cap, rotor and pcv valve........ The only time that it is doing it is when I am idling...... then when under a load, like going up a hill it makes a grinding/pinging noise.. and doesn't have the power it once had... since it started my mileage dropped from 23 on hwy to 16........ any ideas??? I tried reading codes, but am not getting power to the port......
Old 01-25-2009, 02:40 AM   #2
If that's an OBD-1 like I think it is, couldn't you pull codes by
jumping A and B on the ALDL, and counting the flashes ?
Course check your dash warn lamps work at key on first...
Old 01-25-2009, 04:36 AM   #3
batty1214's Avatar
Im not sure what you mean by jumping a and b on the aldl....... and Im pretty sure it is a obd1...
Old 01-25-2009, 06:03 AM   #4
check the fuse for the lighter for the power problem. sounds like the O2 may be weak, you will need a scanner to read it. the pinging is spark knock, did you disturb the timing or knock the wire off that you disconnect for setting the timing?
Old 01-25-2009, 08:09 AM   #5
silverhairdeere's Avatar
try this run a jumper wire from a to b that will give you a code .
shd
Old 01-25-2009, 01:21 PM   #6
batty1214's Avatar
The miss started before I changed everything...... and nothing this far has helped it..... I'll try jumping the code.......one of my friends was wondering if It might be my cam or valves.... Is this a possibility?
Old 01-25-2009, 01:25 PM   #7
batty1214's Avatar
that really isnt that hard to get codes then..... huh. have to try that tonight
Old 01-25-2009, 03:19 PM   #8
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
here is a site that will define the codes for you also.
Old 01-25-2009, 04:28 PM   #9
batty1214's Avatar
okay, if the computer has codes on it, should the service engine soon light already be on?
Old 01-25-2009, 06:09 PM   #10
No they would be stored, Did you get your reader to work?
1996 chev silverado code reader boston410 Chevy Truck Forum 4 12-28-2008 11:33 AM
Will This Work? pumba Chevy Truck Forum 3 07-01-2007 10:29 AM
Equus Innova 3130 Obd Ii 2 Code Reader Scanner Tool cajunwoodrick GMC Truck Forum 5 06-07-2007 02:13 PM
A/C don't work truckpower Chevy Truck Forum 3 05-30-2007 05:59 PM
2004 F350SD CAN/OBD2 Reader MrDoug Ford Truck Forum 2 04-21-2007 05:57 AM
