Results 1 to 5 of 5
Thread: 96 sierra-cruise control not engaging
    Jan 2009
    7
    Hello! I just bought a 1996 gmc sierra. In pretty good condition. I was on the freeway trying to get the cruise control to work. I tried every combination, but it would not engage. I just checked the user manual for the correct procedure. I am going to try that out tonight.
    If, for some reason, the cruise control is not working. What are the common issues? Where should I start diagnosing the problem? Is there a fuse that I can check?
    Mar 2008
    N.Y.
    10,794
    Blog Entries
    1
    welcome to the forum,
    Yes there is a fuse for it
    Senior Member silverhairdeere's Avatar
    Feb 2008
    land between the lakes tn
    1,831
    switch on column, servo , ecm ,vacuum hoses , control module on the right side of brake pedal switch . vehicle speed sensor sensor ,on some of these you can test with a multi-meter .
    shd
    Jan 2009
    7
    Looks like a manual is in order. Thanks for the input.
    Feb 2008
    1,831
    on my 1996 lumina it was the ecm . yep i didn't know it controled it too .
    shd
  1. Cruise Control
    By larryeaston in forum Chevy Truck Forum
    Last Post: 11-28-2008, 02:54 PM
  2. 94 no cruise control
    By barbermike34 in forum Chevy Truck Forum
    Last Post: 10-12-2008, 03:13 PM
  3. Cruise control help
    By woody367 in forum GMC Truck Forum
    Last Post: 09-09-2008, 10:29 PM
  4. Adding Cruise COntrol 2003 Sierra
    By gaiter in forum GMC Truck Forum
    Last Post: 09-26-2007, 05:52 PM
  5. cruise control
    By vanhal in forum Chevy Truck Forum
    Last Post: 12-19-2006, 06:09 PM
