| More issues The Fuel gauge is all over the place in a 2002 GMC duramax diesel 6.6 What is the cause And the passenger side window motor sounds like a broken starter and the window doesnt move |
| fuel gauge problem sounds like you have something grounding out. the window problem might be stripped gears. best way to diagnose this is to break into the door panel and investigate further. |
| the fuel gauge wire had lost some of its insulation rubbing on the body and the windows cable had snapped |
| Senior Member Join Date: Nov 2009 Location: winchester, va
| gauge float
__________________ No Engine Has Enough Power/Torque For What I Want It For I Can't Leave a Factory Truck Alone Without Doing a Mod to it This signature belongs to davbell22602. Any duplications will be prosecuted. |
| funnily that wouldnt be too bad because the box is almost removed on it i had it at my place the other day and slid under it and there wasnt a single bed mount bolt it our 5th wheel hitch was holding the bed down it seems the painters must have forget lmao |
| I have a 2002 Silvy and the window regulator takes less then an hour to replace from start to finish all tools and the new part in hand. I had NEVER done this before and it took under 40 minutes(I had the panel off all ready) back together and working panel back on etc.
__________________ Siggy by Crimson Dragon >>>>>>>>>>>>>>> ![]() _____________________________________________ |
| air conditioning issues | animalsrule | GMC Truck Forum | 13 | 09-20-2008 02:19 AM |
| 97 GMC 4x4 starting issues | TOTEGOATPATTY | GMC Truck Forum | 3 | 09-06-2008 09:11 AM |
| Front End Issues | carljuniors | Chevy Truck Forum | 3 | 04-01-2008 06:54 PM |
| abs issues | HVY84CHVY | GMC Truck Forum | 5 | 01-02-2007 09:24 AM |
| A C issues | mikerike | Chevy Truck Forum | 9 | 07-24-2006 05:46 AM |
