Old 02-12-2009, 07:40 PM   #1
waterloo88chev's Avatar
waterloo88chev has a spectacular aura aboutwaterloo88chev has a spectacular aura aboutwaterloo88chev has a spectacular aura about
Shaking
So I'm glad to finally have my truck up and running again (I'm sure some of you saw my troubles in my most recent ongoing thread), but today a problem came up. For the first time, my truck was shaky and vibrating pretty bad at highway speeds. Then, when I went to slow down to turn, the truck started shaking pretty bad. I pulled over and got out to look for any obvious problems and I saw nothing. Then when I started getting going again, the next time I slowed down from higher speeds the truck started shaking. BUT, if I would just lightly press the brakes to slightly decrease my speed the truck wouldn't shake.
So I ask this... Can some kind of faulty brake part cause problems slowing down from only higher speeds but not just slightly decreasing my speed?
Is there a chance it is some sort of transmission problem?
Any help is appreciated, thanks.
waterloo88chev is offline   Reply With Quote
Old 02-12-2009, 10:10 PM   #2
do you feel it through the steering wheel or the seat? if you lightly ride the brake when it shakes does it stop? It could be caliper siezure, is there any pulseation when you use them? How are the tie rods?
Old 02-13-2009, 07:36 AM   #3
Ditto to the Tie rods.
Old 02-13-2009, 07:42 AM   #4
the shaking is through the seat, steering wheel, everything. The whole truck starts shaking. As for the tie rods, I just replaced all of them. So I know they're good.
Old 02-13-2009, 10:02 AM   #5
I think it's time to jack it up and wiggle, shake, and pry everthng in the front end to make sure it's safe
Old 02-13-2009, 07:24 PM   #6
72'CaminoKid's Avatar
dreaded death wobble. catch me up to speed, what all has been done to your truck recently? this will maybe help pinpoint the cause
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 02-13-2009, 07:40 PM   #7
sounds like the problem comes up when you take the load off whatever is broke/loose. check your engine and trans mounts along with u-joints. how many miles on the drivetrain?
Old 02-13-2009, 08:20 PM   #8
ukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to all
I was much sure I had "death wobble" post here before, and it vanished..
Anyhow:
idler, pitman, and hub bearings. took idler and driver side bearing times steering shock to rid of it on my truck.
ukrkoz is offline   Reply With Quote
Old 02-13-2009, 10:28 PM   #9
Since I've had it... I've replaced all tie rod ends and steering damper and had it aligned. Replaced all the vacuum lines and the water pump, but those should have nothing to do with it. Supposedly the engine and transmission were rebuilt 25,000 miles ago.
Old 02-13-2009, 11:39 PM   #10
Originally Posted by ukrkoz View Post
I was much sure I had "death wobble" post here before, and it vanished....
Was this the one you were looking for ?
Grinding from front when making left turn
Violent Shaking waterloo88chev Chevy Truck Forum 6 08-06-2008 08:00 AM
06 dually shaking plowboy9400 Dodge Truck Forum 3 02-13-2008 04:17 PM
shaking shagn84408 Dodge Truck Forum 5 02-01-2007 05:21 AM
Shaking... 1bj Nissan Truck Forum 5 11-29-2006 10:09 AM
bad shaking when driving 98Z71 Chevy Truck Forum 10 10-26-2005 08:20 PM
