Old 02-20-2009, 08:59 PM   #1
blackwarbeast's Avatar
blackwarbeast is on a distinguished road
vacuum leak in cabin area?
95 gmc 1500 xcab...everytime I press the breaks I hear a ssssssssssssssss sound...like a vacuum type hiss. the truck is currently only braking with the front two brakes, the back two needs the works (shoes, hardware kits, etc.) . Im pretty sure the sound is brake related somehow.
blackwarbeast is offline   Reply With Quote
Old 02-20-2009, 09:03 PM   #2
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
sounds like your vacuum booster has a leak. does the pedal firmer than normal on the first push with engine off. does the feel change at all when you push the brakes?
Kennyray is offline   Reply With Quote
Old 02-20-2009, 09:52 PM   #3
the pedal is usually always soft as ****...not firm at all, just enough to stop the truck when stopping at a light, sign, etc. I figured this was due to it needing brake work. also, the brake line had to be patched with compression fittings but I had a shop bleed the brakes and whatnot. but your right maybe it is something with the booster..if so how do I fix that?
Old 02-20-2009, 10:30 PM   #4
silverhairdeere's Avatar
first check the vaccum hose and the plastic piece , if ok replace the vaccum booster .
shd
silverhairdeere is online now   Reply With Quote
Old 02-21-2009, 10:48 AM   #5
If you are patching for leaks, it's time to replace! compression should NOT be used on brakes, only flare, bubble,etc. They make an easy to work with soft line, that bends and flares nice. Do yourself a favor and do it right, the consequences aren't worth it!
Old 02-21-2009, 09:05 PM   #6
I agree, the lines will blow out of those compression fittings on a panic stop.
Scav.
vacuum prob austinpowers Chevy Truck Forum 5 09-08-2008 07:17 AM
vacuum problems geoemojr Chevy Truck Forum 6 12-19-2007 08:28 PM
vacuum problem worm Chevy Truck Forum 3 03-29-2006 09:00 PM
cabin pressure scottie Chevy Truck Forum 10 01-25-2006 10:54 PM
Cabin Fever, Week 6: Enter the Spin Zone (Poughkeepsie Journal) trucknews Truck News (headlines) 0 03-03-2005 01:30 AM
