Old 02-21-2009, 06:59 AM   #1
silverhairdeere's Avatar
Question Another half baked idea
along with the homemade rear roll pan this summer , while on the toilet i came up wit this home made duel exhaust made out of round fence post or electric conduit and ran outside the frame rail (keep heat away from gas tank) and exiting in the rear lower bed panel like old 65 mustang gt exhaust outlets . COMMITS AND SUGGESTIONS NEEDED .
shd
Old 02-21-2009, 07:49 AM   #2
Erock80's Avatar
Erock80 is a jewel in the roughErock80 is a jewel in the roughErock80 is a jewel in the roughErock80 is a jewel in the rough
Hmm... redneck engineering at it's best, i like it! It's not a half-bad idea... basically galvanized tubing that won't rust right, is that the idea? I've seen several trucks with the exhaust through the roll pan like that so it's obviously do-able. Go for it. Except would the tubing handle being welded? I'm not positive it would, but worth a shot.
Erock80 is offline   Reply With Quote
Old 02-21-2009, 08:54 AM   #3
Hmmmmmmmmmm....... why not experimentation is one of life greatest pleasures
Old 02-21-2009, 09:58 AM   #4
I believe the challenge to all of this would be getting the exhaust to the outside of the frame. You will have to go under the frame somewhere, and this will create a rather low clearance issue.
Then you will have to route this stuff around the rear springs which are outside of the frame too, and this area will be very limited on space.
Old 02-21-2009, 02:01 PM   #5
only 3 responces , i'am mad as **** and i'am not going to take it any more (move qute) i.am ,i'am++++++++++
shd
Old 02-21-2009, 02:22 PM   #6
You could avoid the problems that 75 pointed out by inverting the headers,
coming out through the hood, and sweeping over the roof into the bed.
Idea is no worse than other stuff present when you had the original idea.
As a bonus, as it crosses the roof (as true duals of course),
you could use a couple old kegs as cats. VERY styling !
Harder to get in garage, but you'd want to park where everyone could see it anyways.
Old 02-21-2009, 05:01 PM   #7
Erock80's Avatar
I know... cut big holes in the frame and run the pipes through there! That'll be great
Old 02-21-2009, 06:00 PM   #8
That's the spirit !
Old 02-21-2009, 07:05 PM   #9
why not reverse the headers and teminate the pipes 6" above the hood like at the pulls
Old 02-21-2009, 07:06 PM   #10
if you have ever watched gearz on speed channal he did the same thing , only at the bottom and reinforced it .
shd
Need in-put on this idea? gmctrucks General Truck Forum 14 01-02-2009 02:41 AM
Baked beans. gmctrucks Off-Topic 0 05-10-2008 12:43 AM
heavy half ton strokin350 GMC Truck Forum 11 04-01-2008 09:46 PM
ok what is a good idea.. joejoehead Toyota Truck Forum 34 10-01-2007 05:31 PM
Random Idea SuperBen General Truck Forum 3 04-12-2007 07:36 AM
