Old 02-26-2009, 05:26 PM   #1
partsman is on a distinguished road
Question What anti-freeze?
I am curious about my anti-freeze, on the used 96 truck I bought I checked with a hydrometer and came up with -10°F, which is too low for my liking, and the other thing is it looks like light green or yellow in colour, is it possible they changed types?
Should I use Dex-cool, and if so do I have to run a hose to flush out the old first, then fill with new?
partsman is offline   Reply With Quote
Old 02-26-2009, 06:55 PM   #2
No on that old of a truck stay with the green, green sounds like vavoline or napa, yellow is usually prestone. I always like to keep them lower than -20. if it looks clean drain a gallon out and put a gallon of whole antifreeze in, save the drained for adding later
Old 02-26-2009, 07:17 PM   #3
must be a northern thing. it got down to 20 degrees here once. that is 20 above zero. cold night that night.
Old 02-26-2009, 07:50 PM   #4
20 thats t-shirt weather
Old 02-26-2009, 09:49 PM   #5
chengny's Avatar
chengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to behold
It takes a lot of very cold (below -20F) days in succession (and a situation where the vehicle sees no sunlight and is not started) for the core temp of a motor to reach that point. Even then, the coolant does not "snap" freeze into solid ice, but rather turns into slush by degrees first.
And, always bear in mind that, along with the antifreezing properties that ethylene glycol does contribute, you also loose some heat transfer capacity that plain water does so well.
A 50/50 mix is the max you should ever require - and even that is too rich.
Remember, that as soon as your engine warms up, it has no idea whether it's July or January outside the engine compartment. The internal temps are just as high and all that heat needs to be picked up from the cylinder walls and heads, carried away by the coolant and then given up to atmosphere in the radiator. Water does this much more effeciently than EG.
Mix your coolant to protect down to 0 and install an in-line heater in the lower radiator hose. Then, on those few nights each winter, when you are really concerned about ice up, just plug it in. Makes for a nice easy start it he AM and the initial thermal stresses are greatly reduced.
Your motor thank you come summer when the coolant is more water than EG.
1986 Sierra Classic
Still Stock
chengny is offline   Reply With Quote
Old 02-27-2009, 06:16 AM   #6
antifreeze also raises the boiling point! stay with the -20 and be safe, it not only protects the engine but all the attached hoses and heater core.
Old 02-27-2009, 07:14 AM   #7
You want to stay with a 50/50 mix. That is in the area of -30 F. You have to remember if you have air cond. you need the 50/50 . If you go with a lighter mix you should ad rust inhibtor-lube to protect the cooling system.
Scav.
Old 02-28-2009, 02:00 AM   #8
chengny's Avatar
Over use of ethylene glycol
Certainly didn't mean to imply that coolant containing a reasonable amount of ethylene glycol was not a good thing. Rather, I was trying to point out that people can sometimes forget what the purpose of the coolant is. In their quest for protection against lower and lower temps, they can get to the point where all they think about is freezing point.
The primary purpose of the coolant in an engine is to remove the heat of combustion to atmosphere. And while EG can certainly lower the freezing point of the coolant, it also signifcantly impacts the specific heat capacity (i.e. the ability to transfer heat effectively) of it as well.
Only offering another example of how sometimes "more is not necessarily better".
Please look at the attached charts, they are simple, yet quite effectively demonstrate that freeze protection comes at a cost.
1986 Sierra Classic
Still Stock
Old 02-28-2009, 04:47 AM   #9
I've read basically the same charts in regards to my outside boiler for the house! it is a non pressurized system, and de-oxygenate must be used! If you want to run your collant at 0 degrees so be it, however I (and speak only for myself) would never reccommend >-20 for normal use.
BWAI
Old 03-02-2009, 08:52 PM   #10
chevyguy's Avatar
As long as its well below freezing I would let it eat. No reason to raise the temp. Its not hurting anything where it is. My truck is at zero adn so is both my cars. I now live in Alabama and if it get to below zero I have a real problem.
USMC 92-96 USCG 98 to present
Tags
coolant
351 freeze plugs liftedtrucks4me Ford Truck Forum 6 06-13-2008 08:50 AM
Freeze Plugs mxer201 Mazda Truck Forum 8 03-15-2008 08:53 PM
How do you drain the anti-freeze 95 K-1500 larbec7 Chevy Truck Forum 10 01-30-2008 11:02 PM
defrost smells like anti-freeze gustofson Ford Truck Forum 4 01-19-2007 10:27 AM
Anti freeze leak none on ground 92Jag Chevy Truck Forum 29 10-16-2005 10:16 PM
