| terminal ? I have a 95 1500 GMC with the auto. One time over a yr ago when it was quite cold.. about zero .. engine not warmed up.. drive did not engage like going to neutral. Only once never again till today . It was 40 deg out engine not warmed up and it did the same thing. I have notice a little lag on the drive when engine is cold. Kind of like revving the engine maybe 50 to 100 rpm before engaging the clutch on a manual. Could this just be a dirty filter? or am I looking at a terminal situation ? Scav. |
| slow go hey scav have you checked the fluid level and condition ?might just need a flush and new fluid .it takes a while to move the oil around when it's cold . at least drop the pan and see how much junk is in it before you pitch it . ![]() |
| | #3 | |
No history on the truck. Will have to wait till next week to drop the pan on it. Scav. | |
| play safe and drop the pan and change the filter then re-fill, If its high mileage a flush can break-away a sludge bomb that could kill the poor girl! |
| Wondering if I should put in an additive to soak up some of the gunk . Just a little nervous about knocking chunks loose like you said. Wonder it the right stuff would just desolve it rather than knock stuff loose . I have the filter and oil ,just might go at it tomorrow. Scav. |
| I would use a stabilizer maybe like lucas or something, as long as it doesn`t have alot of detergents in it... |
| Work Begins on Lagos Truck Terminal Soon (This Day) | trucknews | Truck News (headlines) | 0 | 05-12-2005 06:30 PM |
| ABC Asia Pacific - Pakistan truck drivers blockade major oil terminal (ABC Asia Pacific) | trucknews | Truck News (headlines) | 0 | 03-31-2005 10:30 AM |
| Truck terminal plan approved (Louisville Courier-Journal) | trucknews | Truck News (headlines) | 0 | 12-01-2004 02:30 AM |
| Funds hunt for truck terminal (The Telegraph) | trucknews | Truck News (headlines) | 0 | 08-16-2004 04:30 PM |
