Old 03-13-2009, 09:32 AM   #1
gejandsons is on a distinguished road
slack in front differential
04 gmc extended cab 4wd
While greasing front end we found 90 weight oil leakng from the seal on the driver's side of the front end.
Seal is apparently bad. The flange on the differential side that the axle is bolted to has some up & down movement. Probably the cause of the seal leaking. Local GMC service rep says the seal keeps it from moving. I say he is full of ****, that the bearing on the end of the differential is going out. Any thoughts from someone?
Thanks in advance
gejandsons is offline   Reply With Quote
Old 03-13-2009, 10:32 AM   #2
stumpuller454's Avatar
I would have to say there is something OTHER than a seal issue.... I have replaced those seals before and i certainly donot think they center the shaft! Its just a seal!
Unless somebody corrects me....
Old 03-13-2009, 11:00 AM   #3
Thanks for the feed back.
Old 03-13-2009, 01:59 PM   #4
Find a better dealer!
Front differential grinding 2001 s10 toby345 Chevy Truck Forum 2 12-07-2008 07:40 AM
Front Differential Leak Charlieb GMC Truck Forum 5 04-09-2008 11:45 AM
Front differential seals mjeltema Chevy Truck Forum 3 08-20-2007 10:08 AM
Differential Rebuild Cost? 74vert Chevy Truck Forum 5 07-24-2007 08:47 PM
Differential ratio riverasierra GMC Truck Forum 2 02-19-2007 04:58 PM
