| I have the 6.0 in my 2500HD. I noticed the oil cooler tube is leaking at the connection to the radiator. Is their an o-ring that may be the cause? If so can it be replaced or is there an other reason for the leak. i dont want to have to replace the whole assy. at $70.00 from NAPA. |
| the threaded connection?? if so use some blue-bloc sealer on it!
| It appeared to be leaking where the pipe goes into the radiator fitting. I know there is a clip that holds the tubing into the radiator but im not sure if there is an oring to prevent leaking or if its how the shape of the fittings match up. |
| | #4 | |
| Oil Leaking Quote:
| There's a O ring, it's in the threaded fitting that goes into the radiator.. If that's the cause , they don't cost much at all.. replace the fitting and be done with it. Make sure to inspect the pipe for signs of kinking from being side loaded or bent/worn where the o ring seals against it. If it is .. it will only leak again.. and you will need new cooler lines too. |
| Last Activity: 04-01-2009 12:36 PM i dont think the cowboy is coming back. maybe he still doesnt hae that problem after nearly 4 months. |
| Maybe he doesn't like us
| I have an idea... Lets collectively hate him for not coming back. That'll show him.. and maybe deter others from coming here and making a post, only to abandom it afterwards. |
| Full Member Join Date: Jul 2009 Location: Cibolo Texas
| The nerve of some people... ![]()
__________________ Zembonez - AKA Crazy Clown |
| | #10 | |
| oil cooler | bigz | Chevy Truck Forum | 22 | 11-21-2008 11:49 AM |
| oil cooler | bigowe | Ford Truck Forum | 1 | 09-05-2008 08:11 AM |
| Trans Cooler question | racejmac | GMC Truck Forum | 4 | 07-30-2007 10:49 AM |
| Installing an Aux. Tranny Cooler | corey | Chevy Truck Forum | 4 | 08-30-2006 07:12 PM |
| oil leak | scottie | Chevy Truck Forum | 10 | 01-22-2006 07:00 AM |
