Old 04-09-2009, 08:32 PM   #11
hotrodpc's Avatar
Thanks Brad, Yep it worked. Now what kind of locker is that? Detroit???
Old 04-09-2009, 08:34 PM   #12
i can tell you its not a lincoln. one can tell from the lack of weld beads. not that i would know anything about that.
Old 04-09-2009, 08:41 PM   #13
hotrodpc's Avatar
It has some similarities to a detroit, but I am not sure it is. I'd hope not. Detroit Lockers are supposed to be the best money can buy I've heard. Although, I have not a lot of experience with lockers and any differnetial for that matter. I have set up an old 62 Chev 3rd member a couple of times, and watched a guy set up a 12 bolt chev with a limited slip and thats about it. Changed many spiders gears and axle bearings, but I don't conisder that rear end expecience since it does not involve setting ring and pinion lash.
Old 04-09-2009, 09:06 PM   #14
stumpuller454's Avatar
Its a detroit, mostly i bet your thinking it should be a complete carrier assy, for some reason the only detroit locker model available for the 10.5" chevy 14T rear end installs into an gm open carrier. (as pictured)
Anyways got it all in there, setup her up, went for a drive, all is good, can`t even hear it, (good thing) the only problem is i think i need longer mudflaps to keep the rubber from sticking to the fenders.... pics to come....
Old 04-09-2009, 09:10 PM   #15
hotrodpc's Avatar
Oh, I get it. I did not know that. I thought the detroit locker had to have its own carrier assembly. Maybe then the Detroit Locker isn't all what I thought it was. That will be the first time I have ever heard of someone tearing up a DL.
Old 04-09-2009, 09:28 PM   #16
most do come as a complete assy, just not for the 14T.....
Old 04-09-2009, 09:30 PM   #17
Originally Posted by stumpuller454 View Post
check out the damadge!
this is the factory G80 (Gov-Lok) that exploded..... not a DL.
Old 04-09-2009, 09:31 PM   #18
hotrodpc's Avatar
My dad truck is a 94 1 Ton Chassis Cab. I believe his may have a Dana 70 in it.
Old 04-09-2009, 09:33 PM   #19
hotrodpc's Avatar
Ahh, OK, now that makes sense. I am not suprised to hear the G80 took a dump. Although their most common failure is the strip to teeth on the outer gear. It is more of a cam lock design and fairly weak. Along with its only good for very low speeds, so you can give it up if you wanting to do a burnout to heat your slicks, unless you can get them hot at 8-15mph.
Old 04-10-2009, 03:23 PM   #20
so here is proof that a detroit locker works....
just in case the pic doesn`t work....
http://i457.photobucket.com/albums/q...54/burnout.jpg
Tags
diff lockers, differential
powertrax 8.8 31 spl locker f/s t5stang91 Truck Classifieds 0 03-03-2009 06:33 PM
wtb posi or locker warlordxx Chevy Truck Forum 6 01-24-2009 11:37 AM
Locker Troubles MORROWMUDDER 4x4 trucks / off road 12 02-23-2008 02:59 PM
power wagon, locker Q's mtfit Dodge Truck Forum 7 12-02-2007 09:13 AM
The victim has arrived chevyguy Chevy Truck Forum 5 08-14-2006 01:31 PM
