| Junior Member Join Date: Apr 2009
| sporadic miss '91 GMC with '92 350 misses sometimes when it is started. May miss for 1 to 3 miles so bad it will hardly go up a hill. I put new plugs, cap, rotor, coolant temperature sensor on. Wires are good. Sometimes it starts and runs great. Never misses when a mechanic or tech is around. I'm wondering about the ignition module or pick-up coil. Any ideas? |
| Could be your EGR or IAC valve, (Idle Air Control) |
| check for vacuum leaks sparay soapy water on plug wires, watch for cracking noise. spray carb cleaner on vacuum lines and gaskets, if it bogs from some area - you got your culprit. definitely clean EGR and PCV. |
| Senior Member Join Date: Mar 2009 Location: South Jersey
| I had a few of those trucks in my fleet. Question is what does the intake look like and is it Throttle Bottle Injected. Other is, any codes coming up. |
| Thanks for taking time to reply. I'm reading them but haven't had time to act on advice yet. rpp |
| Skip, miss, cut-out | Flowtech1ton | GMC Truck Forum | 6 | 10-16-2008 07:37 AM |
| 2002 f-350 7.3 engine miss | JonnyBoy | Ford Truck Forum | 3 | 03-02-2008 12:55 PM |
| 2001 miss | dthompson | Chevy Truck Forum | 3 | 02-20-2007 09:53 PM |
| Miss or hesitation? | spacoli | Toyota Truck Forum | 4 | 01-07-2007 12:10 AM |
| bad miss in a 3.0 v6 Nissan | srw45 | Nissan Truck Forum | 0 | 12-11-2005 08:21 AM |
