| now it's your turn to help me !! NOW sorry sometimes i like to bark just to hear myself . the problem ,hadn't started THE 1989 G.M.C. 1/2 TON AUTOMATIC WITH 5.7 AND AIR , NO EXTRA POWER OPTIONS . in about 2 weeks and bingo it was nearly dead charged up to about 12.25 volts (multi-meter) did the test light between the pos cable and battery thing hardly lite up at all (light drain) so charged it up to 12.50 volts , un hooked both cables waited overnight checked the volts on the unhooked battery 11.55 volts . is this normal or is my bought in sept 08 battery(rural king) going bad ? is their another test to see what the drain is on a battery other than a test light . if so what should a normal drain be ? ![]() shd |
| a good battery should not loose a charge like that. have you tried to clean the battery case and terminals. a dirty battery will loose voltage.
| both cables were unhooked over night and it still almost droped a full volt from 12.50 to 11.55 . shd |
| take it back and get a replacement asap before the full replacement warranty goes out
| That battery is toast, you used the perfect test to prove it. I wouldn't depend on a battery below 12.5v, nor keep one below 12.25v. For that test a "12v battery" is functionally dead at 12v. Remember, 12v name comes from the uncharged value of cells, most of my batts will sit at 12.75v after a couple days disconnected. Possible causes include cracked case or low electrolyte, so check for those before bringing in for warrantee. Damaged plates are most likely caused by low electrolyte or continous overcharge. If it was originally parked with a poor charge, then sat a long time with maybe a dose of cold weather, that could sink it. |
| | #6 | |
| Banned Join Date: Nov 2008
Most automotive batteries have 6 cells each producing 2.1Volts when fully charged. It sould to me like one of the cells in your battery are dead/dying and it needs to be replaced. Sorry.... | |
| SHD how is the new battery working?? ![]()
| can't find the receipt so far . shd |
| won't they take it back without? maybe as long as it's their brand they won't care
| Say buddy what I do my battery is a Interstate I take it to the distributor and they never give me a receipt they don't even charge to check it like a authorized dealer will. I hope this helps you out bud. Also the longer you take to take it to them the more there going to charge you to pro-rate it. Good luck! GMC |
| Tags |
| battery |
| Turn Signals | curtis_98 | Nissan Truck Forum | 3 | 03-23-2009 10:05 AM |
| Can't turn ign key on 96 1500 | aeroned | GMC Truck Forum | 5 | 06-29-2008 08:21 AM |
| GMC van won't turn right | 340doc | Chevy Truck Forum | 6 | 02-27-2008 06:26 PM |
| they had their turn... | peterbilt | Ford Truck Forum | 21 | 07-12-2007 04:26 PM |
| Need Help!! Turn Signals | parrott | Toyota Truck Forum | 1 | 01-07-2007 09:46 AM |
