| | #11 |
| Senior Member Join Date: Jun 2008
| i agree with hotrodpc, cold and not running it will read high, if it's warmed up ,in park and in the hot crosshatch area your good! |
| | #12 |
| Tranny pan removal This just reminded me that someone on here told me that taking the trans pan down would be just as complicated as trying to take out my rounded drain plug. You were right whoever you were....They are just as stuck, if not more so....My brother and I are going to get some of grampas penetrating oil (the real deal before the chemical change) and let that sit for a hour or so. Those mother f-ers will come off then I bet. |
| | #13 | |
don't forget 2 things: 1. you'll have to bend gear shifter bracket away to be able to remove the pan. 1999-05 models.2. be VERY careful when you reinstall pan back. there are 2 connectors in the back of trannie that are known to come off from a wind blow, least to say - pan touch. ends up in do-over. | |
| Tags |
| tranny, transmission fluid |
| Tranny fluid for 2004 sierra HD diesel | cordeiro98 | GMC Truck Forum | 2 | 04-30-2009 05:43 PM |
| where the **** can i add tranny fluid | 89se-5 | Mazda Truck Forum | 12 | 09-12-2008 07:10 PM |
| anybody try to replace tranny fluid and filter? | buttaluv | GMC Truck Forum | 3 | 11-12-2007 07:07 AM |
| New Tranny!!! Which Fluid do I use??? | YngPiggyZ71 | GMC Truck Forum | 13 | 04-09-2006 07:00 PM |
| How much tranny fluid ??? | 84sierra | GMC Truck Forum | 7 | 03-18-2006 11:11 PM |
