Old 06-12-2009, 01:40 PM   #1
badtothebowtie's Avatar
badtothebowtie will become famous soon enoughbadtothebowtie will become famous soon enough
1991 gme 1/2ton to 3/4 swap
hey guy i have a 1991 gmc extended cab long bed 4wd i blew up my 3:08 limited slip rear axle i have a set of 3/4 ton 8 lug axles lined up do u know if there are any clearance problems i need to worry about like cv shaft ect...
IF U GO OUT U HAVE TO DRESS UP WHY NOT WARE A BOWTIE
badtothebowtie is offline   Reply With Quote
Old 06-12-2009, 04:36 PM   #2
batty1214's Avatar
your swapping the front 3/4 ton Independant setup into a 1/2 ton?
Old 06-13-2009, 02:05 PM   #3
no the truck is a half and im going 3/4
Old 06-13-2009, 03:14 PM   #4
not sure about the front but if the rear came out of the same body style it will be a direct swap.
Old 06-13-2009, 04:41 PM   #5
batty1214's Avatar
thats what I was asking, a 3/4ton Indepentent front suspension into a 1/2 ton pickup? Or are you talking 3/4 ton solid axles front and rear?
Im not sure, but Im thinking that the 3/4 ton front setup is a bit different than the 3/4 tons...... I know that on the newer ones, like 2003, you cannot use the parts from a 3/4 ton and put it on a 1/2 ton...... tried it at work, doesn't fit........ or, are you just swapping in the front differential/axle from the 3/4 ton and making the rest of the 1/2 ton parts work with it?
Old 06-13-2009, 04:50 PM   #6
unless the truck has already been sas'd (solid axle swap) there is quite a bit of work to put a solid axle under the front of an independent setup.
Not real clear on the main question. are you talking about changing the CV's shaft in the front out with CV's out of a 3/4 ton? You might not need to do that at all. You might be able to just change the spindle and or hub and keep the same cv shafts...
Old 06-15-2009, 07:04 AM   #7
im taking out my 1/2 ton ifs and putting in 3/4 ifs hubs cv and diff
Old 07-01-2009, 11:25 AM   #8
hammer head is on a distinguished road
as far as i can see it should almost bolt right in i have a 96 ext cab short box ive put a hd one tonne rear axle n springs in just started the front if the tape measure wasnt lying its guna fit a one tonne front end in my half tonne good luck
hammer head is offline   Reply With Quote
1991 gmc a/c help lanniec Chevy Truck Forum 5 08-14-2008 08:55 AM
Dodge Ram 150 1991 northerncanada Dodge Truck Forum 5 05-11-2008 07:41 AM
'85 Chevy 2wd 1/2ton to 3/4 ton Skylar1321 Chevy Truck Forum 1 10-18-2007 08:54 PM
1991 Suburban 4X4 lsphillbilly Truck Classifieds 2 08-18-2007 08:18 AM
1991 abs codes HELP scootman Chevy Truck Forum 1 03-13-2006 06:49 PM
