Old 06-15-2009, 06:26 PM   #1
abgriffin is on a distinguished road
power window problems
i have a 1985 gmc truck with power windows.the windows go up and down but seem like they take forever.you can lift both window glass up and down by hand about inch to inch and half. dont know if thats normal with the age of truck. is there any way to speed it up or change to a little faster operation.my grandfather has one exactly like it and it does the same.i'm a little younger and would like to work faster!!! even aftermarket. any help wou
abgriffin is offline   Reply With Quote
Old 06-15-2009, 09:18 PM   #2
cajun cruiser's Avatar
cajun cruiser is a jewel in the roughcajun cruiser is a jewel in the roughcajun cruiser is a jewel in the roughcajun cruiser is a jewel in the rough
if you've never changed the window motors they're just getting old and wornout, they are not real expensive and not too bad to change
cajun cruiser is offline   Reply With Quote
Old 06-15-2009, 10:17 PM   #3
thanks, i'll try that and see what happens
Old 06-21-2009, 09:04 PM   #4
ukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to allukrkoz is a name known to all
nothing. it'll just work better. buy ones from internet, dealer will rip you off for something that goes bad in 60K miles.
remove door panel. disconnect connectors. there should be 4, maybe 5 x 13mm bolt heads holding regulator frame in place.
disconnect glass from regulator clips, i think, i had to lower glass down like halfway to get to those bolts. then i taped glass to the door on the outside, so that it does not fall down.
remove regulator bolts. give it a smack and collapse it into the door. there's plenty of room to pull it out through a large opening in the door panel.
collapse new one same way, put it in, open, bolt, bolt glass, done.
took me maybe 15-20 minutes to do. i paid something like 70 bucks for mine.
had both of them go bad on me after 60K miles. junk.
ukrkoz is offline   Reply With Quote
Old 06-21-2009, 09:09 PM   #5
jsech01's Avatar
jsech01 is on a distinguished road
Yeah not too expensive. Autozone seems to have the best prices on these motors.
jsech01 is offline   Reply With Quote
Old 06-22-2009, 04:56 PM   #6
chengny's Avatar
chengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to behold
Hey, timely topic - I am troubleshooting my drivers side P/W right now. I had noticed this post the other day, so before de-energizing the circuit I took a moment to time the up/down stroke time on the passengers side.
How long do you think it should take for a power window to go from stop to stop?
I mean a well maintained setup - properly lubed with (but not buried under) white lithium grease, no excessive play in any of the linkage and good grooves for the widow to slide up and down in. And good tight weather stripping.
It is consistently 4.5 seconds stop to stop. And, it doesn't change whether going up or down.
Just mentioning this in case you already meet these specs - you know so you aren't disappointed when you buy all brand new (made in China) replacement parts and get the same (or slower) results.
These trucks are meant to be repaired. Look at the linkage, there are most likely several bushings that can be renewed to bring it back to factory.
1986 Sierra Classic
Still Stock
chengny is offline   Reply With Quote
Old 06-22-2009, 06:25 PM   #7
i just got the replacement regulator/motor assy(aftermarket).it fixed the play(wear) in original.i thought this would be a good time to replace the rubber in the tracks.everything back together but its like it won't slide in the new rubber.removed rubber and the window zips up/down.anyone know what kind of lube i can put in the rubber.its rubber but has a felt on the edge.dont have the panel back on yet.getting tired of this problem.
anybody,help,help,help!
Old 06-22-2009, 07:35 PM   #8
Spray some silicone on the window channels maybe that might help some.
Old 06-22-2009, 10:35 PM   #9
chengny's Avatar
I can almost garantee that it will turn out to be something to do with the alignment of the tracks that is causing the binding.
I cannot recall the exact circumstances, but I have hit this wall before. Everything works perfectly (as individual parts) but when the time comes to actually put it all together... the glass gets about 2/3rds of the way up and then it wants to drive itself right out of the grooves (towards the outside if I recall).
Check this - and I am really reaching back - there are holes in the steel frame that the bolts pass through. I think that the bracketing can be mounted in a couple of different ways, both of which look right. But only one is (right).
Let me look around for an image.
1986 Sierra Classic
Still Stock
Old 06-22-2009, 11:05 PM   #10
chengny's Avatar
[img=http://img251.imagevenue.com/loc241/th_33202_P1010001_122_241lo.JPG][img=http://img105.imagevenue.com/loc599/th_33204_P1010002_122_599lo.JPG][img=http://img193.imagevenue.com/loc67/th_33205_P1010003_122_67lo.JPG][img=http://img180.imagevenue.com/loc661/th_33211_P1010004_122_661lo.JPG]
[img=http://img235.imagevenue.com/loc473/th_33212_P1010005_122_473lo.JPG][img=http://img129.imagevenue.com/loc205/th_33214_P1010006_122_205lo.JPG
[img=http://img198.imagevenue.com/loc794/th_33220_P1010008_122_794lo.JPG]
Pretty pathetic photos I know - but maybe something will give you a hint (the scoring around the bolt holes for example).
Sorry about the pop-ups. Download them and study at your leisure.
Good luck. I will be back in posession of my truck tomorrow, it is an 86 and the windows work. Matter of fact, the regulators and power locks came out of the doors in the images. I will get better shots then.
1986 Sierra Classic
Still Stock
power window help please teemsta Chevy Truck Forum 8 07-14-2008 07:16 PM
Power window problem jenB Ford Truck Forum 4 07-02-2008 04:12 PM
power window mjfco Dodge Truck Forum 2 04-21-2008 07:29 PM
power window repair Charlie390 Dodge Truck Forum 0 04-25-2007 06:59 AM
power window wont go down atk Chevy Truck Forum 1 03-24-2007 05:53 PM
