Old 06-17-2009, 04:16 AM   #11
compression test will help eliminate a mechanical part breakdown, rings valves etc
Old 06-17-2009, 05:17 AM   #12
instead of clearing the code you should have saved the freeze frame data when they were set. it could be anything, the freeze frame would have helped pinpoint it.
i'd rather be hunting
Old 06-17-2009, 06:12 AM   #13
Sneakysportsman's Avatar
Sneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to behold
Sonds like the exhaust lobes on the cam going down. Or the lifters collapsing.
Sneakysportsman is offline   Reply With Quote
Old 06-17-2009, 09:45 AM   #14
Redrocket1045's Avatar
Redrocket1045 is on a distinguished road
Wouldn't the engine miss with a bad lobe/lifter? Once the engine has undergone its 30 second cycle - it will run almost like normal. It idles at around 550(which is not normal) and accelerates fine(without a load). When I gun the engine - I notice some - not a lot - but some black smoke out the tailpipe. As stated before - if I shut off the engine and restart - I have to repeat the process again or she just won't idle(run at 2000 rpms for about 30 seconds).
Redrocket1045 is offline   Reply With Quote
Old 06-17-2009, 11:43 AM   #15
wont miss if this is an exhaust lifter. 550 rpms is not that bad. my 00 idled around 600. this was after i replaced the TPS. it did idle around 1200. have you cleaned any carbon deposits out of the TB?? could be causing a rich mixture, the black smoke, and once you have cleared her throat out, she would start running correctly. might also check the vacuum theory as well just for giggles.
Old 06-17-2009, 01:04 PM   #16
Thanks. Yea, I checked the TB and it's clean. I'm going to check out the vacuum theory next. I'll post the outcome later.
Old 06-17-2009, 06:09 PM   #17
Did you check the fuel pressure regulator?
Old 06-17-2009, 07:47 PM   #18
Yea, the fuel pressure regulator and the fuel pump are fine.
Old 06-17-2009, 07:52 PM   #19
Checked out the vacuum to the booster and there's plenty. If I crimp the hose with some vice grips the idle comes up a tad(about 100 rpm) but it still misses upon start and I have to fast idle at 2000 rpms for approximately 30 seconds to get it to run half decent. This is really pi**ing me off.
Old 06-17-2009, 08:25 PM   #20
like i stated before, we need the freeze frame data to make an educated guess at what the problem might be. it could be as simple as a bad EGR. an EGR that is open at idle can cause a stumble/stall condition. it needs to be put on a tech2 and components tested. i've had an EGR that would go wide open when the computer commanded anything more than 40%. requested values and actual values need to be compared to find your problem.
Rooney safe...by a miracle (Manchester United) trucknews Truck News (headlines) 0 11-10-2004 03:30 AM
Miracle walls at TMS prevent tragic turn in truck race (Star-Telegram via Yahoo! News) trucknews Truck News (headlines) 0 10-17-2004 09:30 AM
