| Full Member Join Date: May 2009 Location: South Texas
| My 99 GMC truck needs a miracle Hi guys. As a newbie to this forum - I'm hoping you all might be able to help. Here goes. I have a 1999 GMC 4x4 Sierra with the 5.3L w/ headers and a cat back system. About 4 1/2 years ago, I installed a Powerdyne supercharger with 39lb injectors and a custom Diablo sport tune. It ran fine till late January. The CEL came on and I erased it. 3 days later it came back and I erased it again. This time the truck was running like **** and missing and it fouled out the plugs. ![]() |
| can`t say i`ve had that problem, i know intake housings can have bad seals and/or be warped and not throw codes. have any of the mechanics driven it with the scanners in to see exactly how its having problems? Plus have you ever considered having a custom tuner a hand at it? thats the way i go, if theres ever problems i just go visit him, he hooks up the laptop we go for a drive then he makes corrections, P.S. don`t burn her down, its probly a simple overlooked problem man, you feel great when you find it!
| What did the compression test show when you changed the plugs?
| for curiousity sake, what was the code for?? |
| If I recall, the first code it threw was a code for the knock sensors(replaced w/new). Then it threw the famous or rather infamous PO300(random miss) Remenber Guys - this truck ran fine for 4 1/2 years with the Diablo program. And also keep in mind - Why does it run well after running it at 2000 rpms for 30 seconds? It seems to clear up - but on the road it bogs down bad. Oh, and if I shut it down for a couple of seconds and do a restart, I have to again keep the rpm at 2000 rpm for approximately 30 seconds and then it shoots up to 3100-3200 rpms. Thanks guys. |
| I'm kinda of **** on this - but what does the compression test tell me? It ran fine for 4 1/2 years till the CEL light came on. Then it started running super rich. Will bad rings or a valve cause this? Wait - can't be a valve cause it doesn't miss fire - once I run it through the 30 second cycle. I have noticed a low engine vacuum at idle and one mechanic said that he restricted the amount of vacuum to the brake booster - and the engine's idle was very smooth. What are your thoughts on this now? TIA |
| Check ALL ground connections, to frame etc. Bad grounds do strange things. Scav. |
| | #9 | |
I read this many times, just trying to get this right, so the engine vacuum IS low? and a mechanic then somehow adjusted the vacuum to the booster? So it could possibly be a ruptured diaphram in the booster, and it causes engine vacuum to be low, restricting it would have gained a little vacuum. are your brakes operating okay? Heres what i would do, pinch of the supply line to the booster and see how she runs, carefully go for a drive (realising of course you will not have brake assist...) but just to see if that changes anything. I`m still feeling your problem is vacuum related. highly possible in a charged engine, and it will certainly cause the problems you describe. The engines MAP sensor will be "fooled" to think your throttle body is open (lower manifold vacuum) and be forcing more fuel in however there is not actually any available causing a rich condition. It may not be much of a problem when your engine is idling or runing below 2000 rpm, but i know my charger starts making boost about 2000-2500rpm so it could be at this pressure were the problem leak gets worst. Let us know what you think....
__________________ SUPERCHARGED 454 K2500 GMC! 450hp and 600ft/lbs http://www.youtube.com/watch?v=WJ27RJHfJKE "sailing with Captain Morgan often!" | |
| | #10 | |
| Rooney safe...by a miracle (Manchester United) | trucknews | Truck News (headlines) | 0 | 11-10-2004 03:30 AM |
| Miracle walls at TMS prevent tragic turn in truck race (Star-Telegram via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 10-17-2004 09:30 AM |
