Old 06-23-2009, 11:46 AM   #11
Banned
merlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to behold
Originally Posted by gmctrucks View Post
Merlin im saying that because the bottle of Mobil 1 says it's not all synthetic also this has come up before that some other members were and weren't aware of it that's why im writing what im writing but again they might have come out with a new one.
Be good! GMC
PS-Merlin im so happy right now im going to see my grandkids & daughter I can't wait.
Ok, I get you. Just be sure the bottle you want to buy says "full synthetic" and you should be all set.
Me misbehave? lol. Never.......
Enjoy your time with your kids, I hope the weather is better there then it is here.
merlin5577 is offline   Reply With Quote
Old 06-23-2009, 07:16 PM   #12
batty1214's Avatar
As far as the Full Synthetic goes in almost any(notable) brand of oil, you are getting a fairly decent product. Depending on the company, they will start with a mineral base stock, and others a man made stock, and a very few use a organic base for their oils......... The basic difference in the oils as someone else stated is going to be the additives........ Which completely makes the different brands quite different. Mobil one is the only synthetic oil that caterpillar recommended for our new 993 loader........ Royal Purple makes and excelent product.... world renowned....... when castrol first started with the synthetic, it took a bit of trying to get it down..... from what I know, they do make a very good product now......
GMC brings up an excelent point...... If you are wanting Full Synthetic, be sure what you buy has it on the label...... the companies cannot(by law) make a blend of synthetics and label it as a full synthetic with a few exceptions.
Now the reason that they say you can run synthetic oil for more than 3000 miles is due to the molecules in the oil....... see, with a mineral oil, you have desired(closed molecules) and undesired(open ended molecules) the desired resist the breaking down that the heat, and shearing effect that the motor puts it through. the open ended do not so much....... the other thing is, open ended molecules can attach theirselves to the others forming sludge deposits.( I know sludge consists of wear material and dirt as well) Another reason is the additives that they add are more easily added and last longer in the synthetic oil, than the mineral oil........ If you change filters every 3000 miles, then in theory, you can skip an oil change........
Now, with the "blends" there are a few companies out there that take used oil, and recycle it....... the ones who do it right, will run it through a 10,5 and a 3 micron filter upon recieving it..... then, they strip the unwanted things out of the old oil, leaving them with a clean, and like new "synthetic oil" The base stock that Full Synthetic comes from is a man made or man altered thing that gives the oil only the wanted molecules........... Then some of those companies will blend a part of the recycled oil, with a part of man made base, and they finish with the adding of additives....... still technically Full Synthetic, but mixes.................. Are they okay, absolutely.
I do know that Mobil1, Royal purple, and Shell are 3 that do not blend for full synthetic....... they do use Recycled oil in their blends............
So Now, that I have made my spill about oils I Ask a question to the rest of you......... what do you all think of using different oil in you motor than what manufacturer recommends????? for Instance.......
Winter, I run a 0w30 Mobil1 in my engine, and summer a 5w30 Mobil1 in my engine........ Is that okay?????
I say yes
And does anyone else know what the
5w in 5w30 stands for???
Sorry so long winded, could have kept going....... I just got back from another 4 day training on the use of oils in the Mobile Equipment for mining from Noria.......
Old 06-23-2009, 07:22 PM   #13
Banned
I say yes
The W stands for winter. The lower the number the better it flows at 32*F. The second # is weight, the higher the number the better it flows at 212*F.
Most manufacturers recommend different oil viscosities for different situations. In the diesels I have tried 5W-40 in the winter and noticed very little difference. I usually run 15W-40 year round. In my gas engine, I run 5W-30 year round.
Old 06-23-2009, 07:24 PM   #14
batty1214's Avatar
nice........... you know your stuff.........
Old 06-23-2009, 07:25 PM   #15
z07
z07's Avatar
I believe the 5w stands for ASE viscosity grade 5 winter.
Bah Merlin's too fast... that's what Nimue says anyway...
Old 06-23-2009, 07:27 PM   #16
Banned
And I didnt even use google, straight form my brain.
Thank you sir, you do as well.
Old 06-23-2009, 08:06 PM   #17
batty1214's Avatar
Thank you sir, you do as well. [/quote]
I got paid for 80 hours to sit and listen to a guy about this stuff......
Old 06-23-2009, 08:07 PM   #18
Banned
Sounds like a good time.
I read it off of wikipedia about 6 years ago......
Old 06-23-2009, 08:09 PM   #19
batty1214's Avatar
Found out that the Noria representative LOVES to talk about synthetic oil.............. 5 hours on just synthetic............
Old 06-24-2009, 08:08 PM   #20
stumpuller454's Avatar
I had used mobile on one of my moms cars, had one bad experience with a batch, tried some castrol and thats all i use.
I`m trying some 5w-50 syntec on the BB right now, it seems to like it. I run it in the supercharger aswell.
Regular or Synthetic Oil?? BillSimm Chevy Truck Forum 40 11-10-2009 09:54 PM
Synthetic oil or not ? XJMUDDER Chevy Truck Forum 23 01-10-2009 06:34 AM
synthetic ATF me Mickey C GMC Truck Forum 2 02-01-2008 07:09 PM
synthetic oils shane dill General Truck Forum 7 02-11-2006 12:48 PM
Castrol sets Camp Survivor Challenge (Manila Bulletin) trucknews Truck News (headlines) 0 04-21-2005 11:30 AM
