Old 06-28-2009, 03:05 PM   #1
screamin rhino is on a distinguished road
2000 yukon xl fuel pump issue
dropped my tank to replace the fuel level sensor.
now I am not getting power to the pump when I turn the key on.
does it have a fuse & relay or just the relay?
any help is appreciated
thanks,
mike d
screamin rhino is offline   Reply With Quote
Old 06-28-2009, 03:17 PM   #2
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
first thing I would do would be to check all connections including the ground
On a quiet night you can hear a Ford rust
Kennyray is online now   Reply With Quote
Old 06-28-2009, 03:56 PM   #3
To answer your question, both relay and fuse... if they are good then check connections. if the fuse is blown find out why
Old 07-01-2009, 04:46 PM   #4
appears my ground is good but I dont think I am getting voltage to the relay in the box under the hood. I checked all the fuses
mike d
Old 07-01-2009, 08:05 PM   #5
you are not getting voltage to which part of the relay?? you should have 4 prongs. 30,31,86,and 87. 2 prongs are for the actuator for the relay that closes the relay when the pump is turned on. the other is for the pump.
Old 07-02-2009, 05:31 PM   #6
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
There's a fuse and a relay. Both in the underhood bussed electrical center. (Fuse block).
NCroadracer is offline   Reply With Quote
02 yukon antifreeze issue heavychevy85 Chevy Truck Forum 39 03-23-2009 07:19 PM
2000 yukon xl 2500 jdkolan GMC Truck Forum 0 02-06-2009 01:22 PM
2000 Silverado A/C issue Lend-a-Fish Chevy Truck Forum 1 06-29-2007 06:29 AM
Fuel pump, fuel tank, filler neck, filter... lassy GMC Truck Forum 6 04-11-2007 06:48 AM
Trans Issue 2000 Silverado 2000Chev Chevy Truck Forum 3 10-04-2005 06:47 PM
