| Truck alarm The only way I can unlock my truck door to enter I must use my remote to unlock the door, if I use the key (you know the old fashion way) to unlock it the !?@* alarm goes off. Is there anyway to shut that off. The truck salesman and the service dept says that there is no way.sorrry... 2009 GMC Sierra 1500 Last edited by scootertrash200; 06-28-2009 at 08:01 PM. |
| i am by far an alarm knowledgable person, but a model and year might help those that do know something about them. |
| no one knows anything about alarms? |
| Call gm customer service, you should be able to unlock it then put the key in within a certain amount of time without it going off
| I say call the 1-800 number on your owners manuel. Good luck! GMC PS-I always use my remote im lazy and my key hole has been painted to match my truck I don't want to mess it up. |
| Guessing here, but there's a switch on the back side of the door lock cylinder, when actuated by using the key to unlock the door, it disarms the vehicle theft deterrent system.. not necessary when using the remote as the Remote Function Actuator sends a independent signal to the BCM to disarm the VTD. |
| If your truck has Content Theft Deterrent ... the only way to lock the truck without arming the system is as follows.. Lock the doors using the key (not the remote) and unlock it the same way when you are ready to re-enter the vehicle. Once CTD has been armed (arming is innitiated by using the key FOB to lock the vehicle) it must be disarmed through theuse of the FOB |
| Should I have my alarm uninstalled? | Lonesome7.3 | General Truck Forum | 6 | 02-18-2009 05:33 AM |
| factory alarm/security woes 2000 1 ton | bgeacook | Chevy Truck Forum | 0 | 02-06-2009 09:05 AM |
| Keyless entry and alarm on new truck? | Grimm | Chevy Truck Forum | 3 | 03-19-2007 04:03 AM |
| Avital Alarm Set-up???? | ttrazor | Off-Topic | 7 | 02-15-2006 09:13 PM |
