| | #11 |
| Full Member Join Date: Jun 2009
| What would I do to fix that? something I could buy and put on... I am not very circuit friendly person here thanks all for the welcome to this site. |
| | #12 |
| knock sensor is retarding your timing.
| | #13 |
| knock sensor = ESC (electronic spark control) sensor? |
| | #14 |
| part of the same circuit, yes. esc changes your timing to match the current condition of the engine (rpm, temp, yadda yadda), the knock sensor is one of the sensors that the esc uses to gather info. when the sensor goes bad, it retards your timing to it's max setting. put a timing light on it to confirm.
| | #15 |
| Thanks Mud - I seen that in my haynes after I posted. I may just go ahead and replace that as well. However, if a knock sensor is bad I was reading it would be a code 43 in Haynes...? I did notice that the connector to the knock sensor was loose and very dirty. So I cleaned and fixed but havn't started it. |
| | #16 |
| Senior Member Join Date: Jan 2007 Location: North Vancouver BC
| code 42 is ignition control circuit.....43 is knock sensor....if it is the knock sensor...i would also check the Electronic spark control module itself...the Knock sensor send a signal to the ESC module.... |
| | #17 |
| my bad, was going off memory.
| | #18 |
| Well mud - your brain frat may have solved my problem. After reading your post I cleaned up that connection to the knock sensor. Ran pretty good tonight. I am going to drive it to work tomorrow... smokensteve - I think that is what you were trying to say in your post. Anyways - Wish me luck! If it does go bad again... I call AAA for a tow... that's what I pay them for! Thanks. |
| Is there any way to tell who left a rep comment? | Chevy_Finatic79 | Chevy Truck Forum | 15 | 04-09-2008 04:36 PM |
| Forest Service Urged to Strengthen Off-road Rules or Risk Failure; Public Has Less than Two Weeks to Comment on Draft Rules (U.S. Newswire via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 09-01-2004 03:30 PM |
| Comment on this review (Carsurvey.org) | trucknews | Truck News (headlines) | 0 | 07-20-2004 03:30 AM |
