Old 06-30-2009, 07:49 AM   #1
sparty2005 is on a distinguished road
water temp gauge
I have a 93' GMC k1500. The temp gauge went out on in so I picked up a mechanical gauge the other day. I thought it would be easy enough to install... can anyone help me out and tell me where the port is for the lead? Thanks in advance!
sparty2005 is offline   Reply With Quote
Old 06-30-2009, 09:55 AM   #2
drivers side of the block. look around the exhaust manifold near the center of the block. easy to do as i have done the same thing. you will have to enlarge the hole in the firewall to feed the probe through because it is a good deal bigger than the factory probe. the probe DOES NOT come off. like any other thermocoupler, a broken wire will not work.
Old 06-30-2009, 11:29 AM   #3
Thanks for the quick reply, I'll take a look when I get home tonight.
Old 06-30-2009, 01:30 PM   #4
on mine, i first found a good spot to enlarge or make a new hole that would not interfere with anything else. i took a step bit and started working on a hole until it was big enough for the fitting to go through. at that point, you can buy rubber grommets at the store to fit around the wire so that the firewall will not hurt it and trash/debris/engine bay heat will not enter the cabin.
Old 06-30-2009, 11:39 PM   #5
Say Brad are you saying that it's just a plug that one has to remove to place the mechanical probe in the hole? Because I want to do the same thing but I still want to keep my OEM gauge working.
Thanks! GMC
PS-I'm wanting to do the same thing as sparty just to be on the safe side.
Old 07-01-2009, 05:32 AM   #6
yes if you have one available
Old 07-01-2009, 05:41 AM   #7
its not per say a plug but it is where the current idiot gauge reads from. his model year is a pain to change in the dash so one could remove the old probe and install this new one in its place. costs less than 20 bucks at the parts house. you can locate a drain plug in the block and remove it, bush it down and make something work, i reckon.
Old 07-01-2009, 11:34 PM   #8
Say Brad im just going to place mine under the dash or some where that I can see it often. I want to leave my dash stock.
Old 07-01-2009, 11:50 PM   #9
hotrodpc's Avatar
I thought there is a mechanical plug in the cylinder heads for temp. I personally like using the head better, becasue that is where you are likely to see the most heat the quickest around the compustion chambers. Cylinder head temp shoudl be the hottest part of the engine in most cases. In my old 64, I had a full set of Stewart Warner good mechanical guages including fuel pressure and vacuum. For my water temp and oil pressure, I also had a biggo red bright light about the size of a Quarter for idiot light to alert me to check the guages if I happen to not be paying attention to the guages on rare occasions. Also the gf drove the truck sometimes and she had no clue what those guages meant, so she was told if the red light came on, shut it down NOW, don't try to make it home or to the next light. Shut if off, coast off the road, and call me.
Old 07-02-2009, 05:45 AM   #10
it is in the head. was i not clear again?? just slap me when that happens.
Anywhere for a water Temp. sensor to go? MotoFreak195 4x4 trucks / off road 2 03-13-2009 08:29 PM
temp gauge Thirdeye Chevy Truck Forum 3 07-23-2008 05:31 AM
Water Temp Gauge 1984heartbeat Chevy Truck Forum 7 09-27-2007 07:05 AM
water/coolant temp sensor? ERIC777 Mazda Truck Forum 4 06-09-2007 10:09 AM
Temp gauge Help claytonfrnk Chevy Truck Forum 2 03-16-2007 06:20 AM
