Results 1 to 9 of 9
Thread: 93 GMC 3500 6.5 diesel smoking problems/questions..
    Aug 2009
    3
    i have a 93 gmc 3500 with 6.5 turbo diesel and it has around 150,000 miles on it. and when i start it up in the morning it starts up but chugs and blows blueish white smoke and will then if i hit the throttle it still chugs and blows smoke, then evens out after a few minutes. Would injectors be the problem? or what are your guys opinions. any input would be great. then after its warmed up and i start it up it doesnt do it, its only when its been sitting over night.
    Platinum Member
    Apr 2006
    Texas
    11,158
    maybe the injectors leaking down over the course of the night. i have had similar problems on a bit of a bigger scale, but might still apply to you in your application.
    Aug 2009
    3
    thats what i was thinking. and once its warmed up and you rev it up it'll blow black smoke but is then followed by a puff of blue. i was wondering if i might just have one bad injector or what. any input?
    Platinum Member
    Apr 2006
    Texas
    11,158
    really wish i could give you a bit more information than that, but we ended up trading off that truck before we got to fix the problem. it could very well be just one injector but the chances of it being that one are slim. maybe one of our resident diesel guys will chime in here with a bit more info.
    Senior Member BernieB's Avatar
    Jul 2009
    3,880
    If it's the injectors running a can of Seafoam or Diesel 911 through it might help, and sure won't hurt.
    * SPACE FOR RENT *
    Senior Member NCroadracer's Avatar
    Apr 2007
    307
    Sounds more like slightly worn valve guides, with the puff of blue smoke n all.
  7. #7
    Aug 2009
    3
    thanks guys, does anyone have any ideas on what i should do?
  8. #8
    Mar 2009
    37
    I have a 94 chevy 3500 with the 6.5 diesel and have the exact same issue. What I am trying right now is some injector cleaner, (I used diesel kleen). I used a 16oz bottle with my past tank of fuel. I don't yet know if this will help or not, If not I think I have a bad injector. The injector cleaner is cheaper than replacing any injectors. You may want to try it. I hope this helps.
  9. #9
    Full Member Square357's Avatar
    Oct 2009
    Washinton State
    24
    Quote Originally Posted by NCroadracer View Post
    How difficult would it be to replace valve guides?
    "Better than power over all the earth, better than going to heaven and better than dominion over the worlds is the joy of the man who enters the river of life IN A CHEVY DIESEL!."
  1. 2001 Ram 3500 diesel auto TPS
    By etcarl in forum Dodge Truck Forum
    Last Post: 08-02-2009, 06:24 AM
  2. Chevy diesel 3500 HD wont move
    By dspabout in forum Chevy Truck Forum
    Last Post: 10-23-2008, 04:47 AM
  3. Replacing clutch on 3500 HD diesel 94
    Last Post: 09-03-2008, 05:50 AM
  4. Dodge 3500 Diesel Dually
    By jw7128jw in forum Dodge Truck Forum
    Last Post: 05-11-2008, 02:46 PM
  5. Thinking of buying 1993 3500 diesel - need help.
    By Catsailor in forum GMC Truck Forum
    Last Post: 11-24-2007, 05:46 PM
