| | #11 |
| and the winer is ? , went out today by-passed the low presser switch with a wire , it was so cold in the cab , i thought about gloves , the compressor ran smooth , no hint of anything , no squeal , no engine bog , no nothing , sooooo do you think it is still low on freon or is it the switch . ![]() shd |
| | #12 |
| without a pressure test, there is no telling. bypassing the switch just tells the clutch to stay in, whether it is low or not. it might be just the switch, but i would pressure test it. if you go and change the switch, it will still act up if it is low. then you spent money on a part that you didnt need. anyone around you own a set of manifold gauges?? |
| | #13 | |
shd | |
| | #14 |
| dont put another can in there unless it needs it. it is very possible to overcharge the system. i guess you can buy a can with a gauge on there and get the same effect. without knowing for a fact that your freon is low, i cant tell you exactly what to do because i dont want to suggest something that is going to ruin your system. find out what the pressure is and that will tell you whether it is the switch or the freon level. |
| | #15 | |
And getting back to the matter at hand... Without pressure readings it's impossible to pinpoint the problem. As others have said, bypassing the switch just keeps the compressor clutch engaged. If your system is low you can damage the compressor that way. And... even if the system is properly charged, bypassing the switch does not isolate it as the problem. The switch could be working fine but you could have a bad plug. Or any one of another dozen reasons. The only way to tell for sure is with proper diagnosis, complete with proper pressure readings.
| | #16 | |
shd | |
| | #17 |
| 22 pounds is low. i would be willing to bet money on that. might go ahead and fill it up to good and if that still doesnt work, change out the pressure switch. if that cures it, then we will know that you were just a tad low. |
| | #18 |
| make sure you have a good connection at the switch, gently move it and hold in various positions and see if the clutch stays engaged
| | #19 | |
shd | |
| | #20 |
| low freon will still cool if there is a little there. i can wire around a system that reads 5 on the low side and get cold air. problem is that when you leave it run like that, it will ice over the evap coils and prolonged use will cause damage to the compressor. the compressor, when low, will not make any unusual sounds or bog down the motor. it will throw a belt before that happens and if it were to bog down, that would mean your compressor is locking up, which is not your case if you said it cooled. |
| 1989 gmc leaking oil help | bulachip | GMC Truck Forum | 4 | 03-27-2008 03:28 AM |
| 4x4 Low in 1989 K2500 | Captain Morgan | Chevy Truck Forum | 3 | 01-05-2008 06:44 PM |
| 1989 k1500 | Rich | Chevy Truck Forum | 4 | 02-10-2007 07:44 AM |
| 1989 GMC Sierra | J-ROCK | GMC Truck Forum | 1 | 02-08-2007 08:59 AM |
| 1989 350 to another vehicle | tnthirshey | Chevy Truck Forum | 3 | 01-30-2006 03:07 PM |
