| 95 GMC Sierra 4WD Transfer Case Switch? Can't get the beast in 4WD suspect bad transfer case ball switch. Located two switches on transfer case one on the front side with 2 pins and one on the back side with three pins. Which is the transfer case ball switch that would actuate my 4WD? Thanks |
| | #2 | |
Scav. | |
| I believe the ball switch is the 2 wire switch, the other one would be the speed sensor
__________________ None of the secrets of success will work unless you do. |
| Changed the Actuator as given it's history I was sure that was it. Getting good electrical check to both actuator and front of the two plugs on the transfer, further research on the site, told me that the ball switch was the forward one. no 4wd lights on the cab shift console. Rock Auto sells a two wire and three wire. Pulled it off and it is the three wire. Thanks for the reply |
| Tags |
| 4wd, ball switch, gmc, transfer |
| '01 Gmc Transfer Case | GM For Life | GMC Truck Forum | 11 | 12-02-2009 01:20 PM |
| cant get transfer case on | brad4eva | Chevy Truck Forum | 1 | 05-20-2008 07:55 PM |
| Need Transfer Case help,, please | Just 1 More | Chevy Truck Forum | 1 | 05-13-2008 05:30 PM |
| 2000 gmc sierra transfer case | wingnutt70 | GMC Truck Forum | 0 | 06-14-2007 04:28 PM |
| 1994 1500 4X4 transfer case lock out switch | Old Trucker | GMC Truck Forum | 5 | 02-05-2007 10:54 AM |
