Old 08-19-2009, 02:24 PM   #1
Sue Bee is on a distinguished road
A different brake issue- high pitched noise
Have an '03 3500 DRW 4X4 that we bought in May with 121K on it. The brakes start to make a sort of high pitched "keen", not a squeal like the wear indicators, but more almost a whistle kind of sound, after the truck has been driven for a few miles (we didn't hear the sound on the test drive). When the driver hits the brakes, the sound stops temporarily, but will start again. Eventually, it usually goes away, but this is after hours of driving.
At the time we bought it, the dealer told us that the brakes had just been done. Brought to a local mechanic, who we trust, they looked at the brakes and confirmed that the pads were new, ceramics. They could find nothing wrong, and so they honed the front edges down a bit, thinking that maybe there was some sort of resonance happening. Didn't help, so we had them dig further, again, everything is newer, looks to have been done recently, and could find nothing to be concerned about.
This is what we are doing with the beast, so we want to be sure that the brakes are going to work:
Does anyone have any ideas of what could be causing this noise, and how to stop it?
Sue Bee is offline   Reply With Quote
Old 08-19-2009, 06:14 PM   #2
scavanger's Avatar
scavanger is just really nicescavanger is just really nicescavanger is just really nicescavanger is just really nicescavanger is just really nice
Did they check to be sure the calipers move freely on their mounts?
I kind of question the ceramic pads. Might be the source of the noise. Also they have to heat up to work their best, so initial braking might not be up to par.
scav.
Old 08-19-2009, 06:48 PM   #3
BernieB's Avatar
BernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond repute
Does it only happen at certain speeds?
Old 08-19-2009, 07:10 PM   #4
sounds like one of the pads is not floating properly
Old 08-20-2009, 06:35 AM   #5
scav.
As far as the calipers, I would sure hope so. The brakes have been looked at 3 different times, once apparently at the dealer we bought it from, which the mechanic that we took it to confirmed that the parts were new, then two times by the mechanic we took it to (who also discovered that the rear tires were too big, and were touching).
We kind of figured that it was the ceramics, but this past weekend, we had it up and back about 130 miles on a camp trip, about 3 hours each way, and the sound was still happening at the end of the trip. I'd have thought that the pads would have warmed up by then. But, we didn't do a whole lot of stop and go, only towards the end when we got back to Illinois.
No, it really is pretty constant until the brakes are applied, then it stops, but will start up again in a few minutes or so, regardless of the speed.
That could very well be, because if the truck hits a jarring bump, it also stops temporarily.
Old 08-20-2009, 08:14 AM   #6
BernieB's Avatar
One more question... Is the sound coming from only one side, or from both?
My thought is that "something" is vibrating at that particular pitch, and the most likely candidate for that would be the brake rotors themselves. I'm wondering if you could have a bearing that's starting to "go" and the vibration from it is making the rotor(s) "sing". If it's only on one side then it's likely a hub bearing. If it's on both sides it's probably a bearing in the transfer case.
I would expect that a change in speed would change the pitch though, so that somewhat negates my theory. Still... it's something to consider.
Old 08-20-2009, 08:16 AM   #7
BernieB's Avatar
Found this too... high-pitched, whine sound
Old 08-20-2009, 01:17 PM   #8
Sound only happens when moving. It seems to be coming from the front, it is really hard to tell, but probably driver's side. The pitch isn't constant, it sort of is, well, it almost sounds like a 3 year old kid whimpering because she wasn't allowed to eat ice cream before dinner... EEEEeeeeeee ahhhhhhhhhhhhhhAHHHHHHHHHHHH eeeeeeeeeeeeeeeeee...
I hope it isn't a bearing, but your theory does make sense. Thing is a beasty bear to work on the underside without a lift.
Old 08-20-2009, 01:31 PM   #9
BernieB's Avatar
So, it's definitely drivetrain related, and not a belt or pulley on the engine. This tends to reinforce my feeling that it's a bearing, or something containing a bearing, that's vibrating. When it vibrates just right the rotors are probably harmonizing with it and "singing". At least that's my theory. I could be completely wrong too.
When was the last time anyone checked fluid levels in the transfer case?
Old 08-20-2009, 01:57 PM   #10
I believe dear husband did this 2 weeks ago when he was checking the oil. Front transfer case is a thought... RSG SM might be needed.
98 GMC Brake Issue Brock GMC Truck Forum 4 07-05-2009 06:34 AM
high-pitched, whine sound jimruss Chevy Truck Forum 2 06-21-2009 08:57 PM
Help trouble shooting a high beam issue mortar GMC Truck Forum 6 12-07-2008 12:34 PM
Brake Bleeding Issue SilverK96 Ford Truck Forum 11 10-09-2008 08:02 AM
