Old 08-22-2009, 04:08 PM   #1
Mudman88 will become famous soon enoughMudman88 will become famous soon enough
Quick issue. Smoke when I start it...
Just a small issue i hope, its done it since i bought it. But, my 89 k1500 has a rebuilt top half of the engine...And when i start it there is smoke that puffs out the exhaust but then its done. Like it burns oil right at startup.Anybody know what it could be?
Mudman88 is offline   Reply With Quote
Old 08-22-2009, 04:14 PM   #2
sounds like valve seal guides to me. lucky for you that this is an easy fix provided you own a valve spring compressor and know how to do it without dropping a valve, whoops!!! i just recently had the same problem and was able to put in the thick oil treatment stuff put out by STP. it did slow it down and eventually stop the leak where i no longer had to oil every so often. you might try that first. it costs you very little for the bottle and the seal guides are very cheap also but more work.
Old 08-22-2009, 07:01 PM   #3
summit will become famous soon enoughsummit will become famous soon enough
Up here in the North Canada Tire sells a product called "Leak Stop" that does a great job on valve seals and rear crank seals. Add one to your oil each time you change it. Unless its real bad it does an amazing job.
summit is offline   Reply With Quote
Old 08-22-2009, 07:45 PM   #4
thanks guys.
new guy no start issue flinch Chevy Truck Forum 30 02-25-2009 11:49 AM
No-Start - Ignition Issue blybrook Chevy Truck Forum 10 10-03-2008 10:12 PM
'89 Chev C1500 puff of oil smoke when i start shawn_huk Chevy Truck Forum 7 07-07-2008 09:25 PM
white smoke on cold start truck067 Dodge Truck Forum 7 04-08-2007 11:41 PM
another engine start issue... johnboytx Chevy Truck Forum 1 01-16-2006 05:07 PM
