| Junior Member Join Date: Aug 2009 Location: Santa Ana, CA
| Hard Starting on a 98 K3500 7.4L I have a 98 K3500 w/ the 7.4L that has a problem with starting. The problem only happens if it has sit for at less then about 10 hours or if it was just shut off and restarted. When turning over it cranks and cranks then finally it will catch and usually a black smoke cloud comes out of the tail pipe and it will smell rich of gas. Anyone have any ideas. |
| Assuming you have given it a recent tuneup......put it on a scanner, check the sensor readings for the o2 sensor, ecm coolant temp switch
| change out your fuel pressure regulator, they regulairly fail, if that doesn`t fix it the injectors are common to leak, i`ve had to put two regs and three sets of injectors in, put in bosch injectors last time and its been smooth sailing.
| Thanks guys I will post an update once I get to try these. |
| hard starting denali | aolson | GMC Truck Forum | 4 | 08-20-2009 01:11 PM |
| 89 CK1500 PU 4x4 hard starting | mudd_jumper | Chevy Truck Forum | 19 | 10-18-2008 03:50 PM |
| Hard starting problem. | mdj21 | Toyota Truck Forum | 13 | 05-16-2008 06:41 AM |
| 76 hard time starting | 76truckin | Chevy Truck Forum | 4 | 11-09-2007 12:32 PM |
| 7.4L Hard Starting | elkfool | Chevy Truck Forum | 6 | 12-31-2006 10:02 AM |
