Old 08-29-2009, 07:47 AM   #1
Mudman88 is on a distinguished road
does the front driveshaft spin even when not in 4 wheel?
Subject asks the question. Im thinking possibly my front ujoints are bad, but I didnt think that the front driveshaft moved when it wasnt in 4 wheel.Does it?
Mudman88 is offline   Reply With Quote
Old 08-29-2009, 08:27 AM   #2
do you have wheel lockouts? if so no otherwise yes
Old 08-29-2009, 08:46 AM   #3
No i dont. Just wondering because when im driving and barely touching the gas I hear something rattling or something...Then if I nail the gas pedal to the floor it goes away until it shifts again, then its back when the RPM goes down..Its wierd..I think its the front UJoints but I dont know.
Old 08-29-2009, 09:51 AM   #4
bubbatrucklover's Avatar
bubbatrucklover is a glorious beacon of lightbubbatrucklover is a glorious beacon of lightbubbatrucklover is a glorious beacon of lightbubbatrucklover is a glorious beacon of lightbubbatrucklover is a glorious beacon of light
Could it be the front u-joint of the rear driveshaft going in to the back of the transfer case?
6" CAN be A LOT when it comes to a body......lift! You CAN outrun a cop you CAN'T outrun a Motorola!
bubbatrucklover is offline   Reply With Quote
Old 08-29-2009, 12:43 PM   #5
better not be, those were relpaced two weeks ago!I put in both the new front u joints, seems to have helped a little.. That driveshaft seems sloppy to me though
Old 08-30-2009, 01:34 PM   #6
The new U joints didnt help
Old 08-30-2009, 08:50 PM   #7
chengny's Avatar
chengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to beholdchengny is a splendid one to behold
Even if equipped with manual hubs (in the disengaged position) it is not unusual to see the front axles and forward drive shaft rotating while the truck is in motion. This "back feed" towards the transfer case is normal and is due to the viscosity of the grease in the hubs. Even though the splines are not physically engaged, the grease provides a sort of "fluid coupling" that will drive the axle/shaft and make it appear that the truck is in 4WD.
But, your hubs are full time - correct? In that case they (the axles and forward D/S) will always be in motion. If the T/C is in 4W they will be locked into the drive train, if in 2WD or neutral the will just be along for the ride. Either way, they will be spinning.
Are you familiar with indexing and phasing of drive shafts? Phase is (see attachments) commonly mixed up and will cause heavy vibration - but is easily remedied.
Indexing is another story. A drive shaft that was not indexed (this simply means marking the relative position of the components to each other) before disassembly can be re-assembled but it will likely be out of balance. Sometimes there are stamped marks on the driveshaft sections to aid in proper reassembly, but most times not.
I realize its too late now but, before tearing a driveline apart, it is good practice to take a can of spray paint and run a good heavy stripe down the entire length. Then, when it is time to put everything back together, there should be plenty of clues no matter how well you cleaned the parts up.
The truck hasn't been lifted lately has it?
does-front-driveshaft-spin-even-when-not-4-ujoint2.jpg  does-front-driveshaft-spin-even-when-not-4-shaftends.jpg
1986 Sierra Classic
Still Stock
chengny is offline   Reply With Quote
Old 08-31-2009, 06:35 AM   #8
I marked off the shaft and everything and put it back exactly how it was supposed to be. It was lifted years back, not recently..My roommated stll thinks it may be bad spark knock.But i just put new plugs in it, wires are about a year and a half old.. It sounds bad...And everytime I get it to REALLY rattle, or ping, whatever, the service light comes on,EGR valve code and code 43, Knock sensor..
Old 08-31-2009, 05:12 PM   #9
Ok, new finding today. When the service light comes on, it doesnt do it anymore...
Anyone? front driveshaft Heinekicken Chevy Truck Forum 9 07-29-2009 05:14 PM
front wheel bounce Batman77 Chevy Truck Forum 4 01-10-2009 08:59 PM
front wheel bearings foxdodgeman1998 Dodge Truck Forum 3 12-28-2008 02:24 PM
front wheel drive mudseeker Off-Topic 7 11-17-2008 08:30 AM
Front Driveshaft guidorr73 Dodge Truck Forum 10 03-16-2006 06:00 PM
