| just got my 1995 k1500 sierra with a 350 (5.7l) motor and drove it 215km to go camping this weekend and worked fine all the way except when I went to start it the started seemed to grind a bit as if it was still half engaged after the motor was running. Now the truck wont start at all and all I get is a loud click that seems to be coming from the starter. Now my truck is stuck in the middle of my driveway! Help? |
| Have you tried getting a jump?
| Hit the starter a couple times with a hammer.(NOT trying to knock it off) Then try the jump thing like Bernie said.( or vice versa jump then hammer) Sometimes the bendix(?) arm gets stuck. If battery is fresh and hammer didn't work could be a starter selinoid(sp?).
__________________ 6" CAN be A LOT when it comes to a body......lift! You CAN outrun a cop you CAN'T outrun a Motorola! |
| There's a SLIGHT chance it could be sitting in a dead spot on your fly wheel. Happened to me a few times on my Monte.
| You mean missing teeth on the flywheel? In that case you'd hear the starter spin.
| | #6 | |
Usually just the bendix,selinoid or dead bat.
__________________ 6" CAN be A LOT when it comes to a body......lift! You CAN outrun a cop you CAN'T outrun a Motorola! | |
| | #7 | |
| nvr mind. Thank you for the advice, one more hit of the hammer proved to be the persuation it needed! just drove my truck into the garage and im glad it turned out to be something simple. |
| Time to change the starter on that one. Oh, and normal battery voltage is 13.8
| You're welcome. Had it happen to me more than once. Double check to make sure the starter bolts are good and tight. If it happens too many more times might have to drop it out and clean it. Don't wanna burn the silinoid up. Could have been a fluke or might be some crud(oil,dirt etc.) in it.
| Picked up truck, starting question | partsman | GMC Truck Forum | 17 | 02-26-2009 11:27 AM |
| Starting it?? | gettembuilt | Ford Truck Forum | 5 | 02-19-2009 07:59 AM |
| Help truck is not starting | colbyj86 | Chevy Truck Forum | 6 | 12-03-2007 07:23 AM |
| Indo-Pak CBMs for starting truck service for trade (The Tribune) | trucknews | Truck News (headlines) | 0 | 09-02-2005 03:30 PM |
| NASCAR.com - Martin open to starting Truck Series team - Jan 31, 2005 (Nascar) | trucknews | Truck News (headlines) | 0 | 01-31-2005 05:30 PM |
