| Noisy Wheel Bearing? 2003 GMC zr2 4wd w/95000 miles. I'm noticing a slight wooh wooh wooh noise when the truck is moving. To me it sounds like a wheel bearing getting ready to fry. I've looked at front wheel hub kits available on-line and am thinking of replacing my hubs up front. They appear to be held on w/3 bolts. How difficult a job is the replacement? I would be working on my back in the driveway. What size socket will I need to break the axle nut loose? Impact wrench ok to use to remove everything? The hubs seem to be around 75~140 dollars which isn't bad if I can do this myself. How bad is rear wheel bearing replacement? Need to pull the axles? Thanks Much |
| If it's a wheel bearing getting ready to go it'll probably be getting warm. If you have an infra-red temp sensor compare the temps of both sides. If not, you can check it with your hand but use extreme caution. Hold your hand near the bearing first, without touching it. If it's really hot you'll feel the heat coming off it. Or use a glove.
| | #3 | |
the job is not difficult to do. memory serves me right, the spindle nut is metric. | |
| I think they are 33mm, but when you buy the assembly it should have a new nut and you can check the size
| Finally getting started. I bought two hub bearing assemblies for $118.00 and they have the correct ABS wire. They are probably junk but will have to do. I am confused about torque settings though. This is a 2003 GMC Sonoma in zr2 trim. I've read in another forum that the axle nut is supposed to torque to 103 ft lbs, the bearing bolts 77 ft lbs. I've seen much higher numbers on earlier years for this truck. The bearings came in the box and the box actually said don't go over 103 ft lbs so I am suspecting this is the right settings for a 2003. I'm hoping to get some level of agreement here from someone who's got a 2003 version of the Sonoma or S-10 ZR2 trim. The cheap bearings were actually assembled overseas from US made parts so they migh not be too bad. At the price if they last 30K I'll be happy. What's a good repair manual for this truck? haynes/chilton or can I get factory? THANKS! |
| front wheel bearing | abgriffin | GMC Truck Forum | 4 | 08-04-2009 08:03 PM |
| wheel bearing | BLK1500 | Chevy Truck Forum | 6 | 05-16-2009 07:30 AM |
| Front Wheel Bearing | TZR2 | Chevy Truck Forum | 23 | 09-21-2007 11:18 AM |
| '02 1500 (4x4) front wheel bearing? | regulator1 | Dodge Truck Forum | 1 | 08-26-2007 06:21 AM |
| Wheel Bearing Adjustment | rwskinner | Ford Truck Forum | 4 | 01-13-2007 07:53 AM |
