Old 08-31-2009, 09:47 AM   #1
ChevyMan65 is on a distinguished road
Codes
Hello everyone,
I have a 2006 Envoy, w/ the 4.2 l6, Ses light came on checked for codes with a friends scan tool before i bought my own, replaced the map sensor after determining it was faulty, truck runs better but still seemed to shake a little. Yesterday the SES light went off by itself, i did not clear it with the scan tool. I rescanned it, and came up with PO506 , and PO106. Any help with this would be appreciated,thanks
ChevyMan65 is offline   Reply With Quote
Old 08-31-2009, 10:18 AM   #2
P0106 - EGR Manifold Pressure Sensor Input Signal is out of Self-Test Range.
Causes:
Bad MAP sensor
Water/dirt intrusion affecting MAP sensor connector
Intermittent open in the reference, ground, or signal wire for the MAP sensor
Intermittent short in the reference, ground, or signal wire for the MAP sensor
Ground problem due to corrosion causing intermittent signal problem
P0506 - Idle Air Control System RPM Lower Than Expected
Causes:
A vacuum leak
An air restriction in the intake air path or exhuast
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Internal engine problem
Failed PCM
Old 08-31-2009, 10:41 AM   #3
Thank you Bradrhale, nothing better than a detailed reply. When my wife gets home with the truck ill check it out
Getting Codes mr. greatwrench GMC Truck Forum 3 05-05-2008 02:11 PM
codes david 87 Chevy Truck Forum 9 04-07-2008 07:00 PM
codes greasemonkeys69 Chevy Truck Forum 3 05-04-2007 03:45 PM
codes PickUpGirl787 Chevy Truck Forum 11 03-28-2007 12:09 AM
OBD-1 Codes Hayden Chevy Truck Forum 2 02-13-2007 08:29 AM
