Old 09-01-2009, 09:19 AM   #1
Mudman88 will become famous soon enoughMudman88 will become famous soon enough
how do i move belt tensioner bracket
Im replacing my thermostat right now, but i need to move my belt tensioner bracket because it too was bolted on to my thermostat housing.. How do I move it, like my book says..It just dont tell me how!
Yes guys, I have a lot of issues with my truck. This is the best place to go though!
Mudman88 is offline   Reply With Quote
Old 09-01-2009, 09:24 AM   #2
its an 89 K1500 with the 350 5.7 liter...
Old 09-01-2009, 09:59 AM   #3
does noone know....
Old 09-01-2009, 10:13 AM   #4
BernieB's Avatar
BernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond reputeBernieB has a reputation beyond repute
Move it or remove it?
To move it (like for taking the belt off) just put a long wrench on the bolt and pivot it. There's spring tension there, and it's easy to slip, so use some care. But once you pivot the tensioner you can slip the belt off and let it slowly go back against the stop.
To remove it do the above, then just unbolt it.
Old 09-01-2009, 10:15 AM   #5
its says it just needs to be moved out of the way...Thats the only way to get to the actual bolts holding down the thermostat housing...
Old 09-01-2009, 10:16 AM   #6
BernieB's Avatar
So take the belt off first then unbolt it and move it. I don't understand the problem...
Old 09-01-2009, 10:40 AM   #7
it didnt say anything about having to completely remove the belt tensioner, which i did now. It just said i had to move the single bracket that bolted down to the thermostat housing!Oh well, now i just have to get it all put back together...Ive never done anything with belts...
exhaust bracket liftedtrucks4me Ford Truck Forum 5 10-06-2008 10:24 AM
a bracket on my truck frame is bent how can i fix it shaunweldin Off-Topic 3 06-05-2008 05:15 AM
7-pin mounting bracket needed jklingel Chevy Truck Forum 3 02-21-2008 11:42 AM
Bracket Nightmare BillySuburban GMC Truck Forum 5 03-09-2007 10:44 PM
Removing AC Bracket - 1990 Scottsdale 4x4 Jesauls70 Chevy Truck Forum 1 02-04-2007 06:28 AM
