Results 1 to 2 of 2
Thread: 1998 GMC Sonoma Not Starting When Cold
    Sep 2009
    1
    I have a 1998 GMC Sonoma SLS 4.3L Truck. It is CSEFI Injection. I have been dinking around with this for so long now and I can not figure out what the problem is. I KNOW it is a fuel delivery problem because if I pour a little bit of fuel down the throttle body it fires up.
    I have replaced the IAT sensor, the coolant temp sensor, fuel pressure regulator, and the fuel filter. The fuel pressure is right where it is supposed to be at with key on and not running and even with it running the pressure is perfect, so its not the fuel pump. I have also checked the injectors and the resistance is in spec.
    It only does this if it sits for a while like 5-6 hours. If I'm running around doing stuff it will start with no problems at all.
    I have pulled the engine codes but they don't tell me whats going on because the ones I pulled don't have anything to do with fuel delivery. So I'm kinda stuck. Any suggestions would be appreciated. Thank You
    Mar 2008
    N.Y.
    10,865
    Blog Entries
    1
    sounds like you need a good scanner instead of a code reader
  1. 1998 GMC Sonoma overdrive ?
    By chewy1010 in forum Chevy Truck Forum
    Last Post: 07-14-2009, 09:00 PM
  2. Replies: 3
    Last Post: 05-11-2009, 04:27 PM
  3. Cold Starting Problems
    By bulltaurus in forum Other Trucks
    Last Post: 11-21-2008, 09:07 AM
  4. cold weather starting 2000 GMC
    By chromedog in forum GMC Truck Forum
    Last Post: 09-11-2008, 08:01 PM
  5. Hard starting, sluggish when cold.
    By prowler40 in forum GMC Truck Forum
    Last Post: 11-06-2006, 08:09 PM
