Old 09-09-2009, 04:49 PM   #1
mack1001 is on a distinguished road
ABS Hydraulic Unit runs continuously
2003 4WD Sierra -- the hydraulic unit on my ABS system runs continuously, even with the ignition off & key removed. Started after running through some wet mud. No visible damage to speed sensor wires. Any ideas???
mack1001 is offline   Reply With Quote
Old 09-09-2009, 06:19 PM   #2
Crmzendrgone's Avatar
You have got something wet that shouldn't of got wet is my guess. Connectors, inside the connectors. Maybe disconnect the battery see if that will reset the system.
Old 09-09-2009, 07:16 PM   #3
Won't reset
That doesn't work. It's my son's truck -- he's been disconnecting the battery every time he stops since the weekend -- no change. Today I unplugged the Hyd. Unit so he doesn't have to do that. Now he's driving with his ABS light glaring and obviously without ABS capability. Found some more info that says it's probably the circuitry in the Hydraulic unit. Costs in the $1000 range from a dealer. Gonna check into options...
Old 09-09-2009, 08:04 PM   #4
Make sure he understands the way to brake without the abs(the old way)
Old 09-09-2009, 08:10 PM   #5
Good point. I am glad I grew up without ABS. Hit the brakes and hope you don't hit it.
Old 09-09-2009, 08:14 PM   #6
If you can open it up try drying it out. might just be an internal connection still wet.
Scav.
Old 09-09-2009, 08:41 PM   #7
Wyley87's Avatar
Wyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to behold
well i've been doing some research on the net about the abs on my truck. i ran across these guys but they could not help me cuz i got a 96 but maybe you can get somthing out of it. The abs pump running continuously is vary common, they claim they can fix them.
ABSFIXER.COM / ABS EBCM Repair
96-GMC C1500 305ci 2WD
K&N FIPK Cold Air Intake
Rebuilt Motor (should have gone 350) and Trans
05 Nissan Xterra 4.0 V6
No mods so far
Cost money to go fast...How fast do you wanna go?
Wyley87 is offline   Reply With Quote
Old 09-09-2009, 09:49 PM   #8
crabtruck's Avatar
mack1001 you should just pull the ABS fuse - that's seperate for motor and doesn't totally kill system.
Tranny and ECM are tied in so better disconnecting as little as possible.
Also with that fuse out you may still be able to get a helpful code read.
Disconnecting battery will wipe out some but probably you can get good info
with ABS (EBCM) plugged in and ABS fuse out (60A on underhood block)
Old 09-10-2009, 01:13 AM   #9
Man either you know your stuff or Shhh you are a jedi master.
Old 09-10-2009, 02:55 AM   #10
crabtruck's Avatar
Definately know my stuff, if "stuff" is a euphemism,
but other than that, you meant it literally.
So,THERE to those who say I don't know stuff !
Tags
abs
Case 570B Back Hoe Hydraulic Pump hotrodpc Other Trucks 19 05-29-2009 10:12 PM
sending unit liftedtrucks4me Ford Truck Forum 3 09-23-2008 07:38 AM
98 S10 V6 Runs rough when cold after 5 miles runs great? STRAYDOG Chevy Truck Forum 17 01-24-2008 02:44 PM
Hydraulic Clutch Problems Catstorman Dodge Truck Forum 3 01-05-2007 01:55 PM
Help on 86 gmc sending unit utah86gmc GMC Truck Forum 1 03-25-2006 06:46 PM
