| Senior Member Join Date: May 2008 Location: stony plain alberta,canada
| 4.3 stroker ? ive heard that you can use 350 pistons etc to build a 4.3 engine could you bore out a 4.3 so that you could use 383 stroker pistions ![]() |
| never heard of a 4.3 being able to be bored out with enough stroke to make 383 cubes. i dont think the cylinder walls could handle that much of a bore. |
| that is not what i meant , i mean to bore the 4.3 as much as you would a stock 350 and use 383 pistons to make like a 295 ci out of the v6 |
| Wouldn't you have to actually stroke it to use the pistons ? If your gonna spend that kind of money just go to the 350. Scav. |
| you refering boring out the 4.3 .030 over and using something similiar to a 400 crank?? |
| The stroke is what your looking for, bore will only net you a few cubic inches.
| I see no reason why you couldn't. A 4.3 is a 5.7 350 with 2 cylinders chopped off the back, so yes you can use 350 pistons, and 350 rods too, along with timing chain, timing cover etc.
| Chevy 305 turned into a 340 stroker???? | claytonfrnk | Chevy Truck Forum | 7 | 05-19-2008 02:31 PM |
| 350 to 383 stroker | smokensteve | Chevy Truck Forum | 3 | 05-08-2008 04:00 AM |
| 383 Stroker... | BryanCregger | GMC Truck Forum | 7 | 03-26-2007 02:33 PM |
| Cali Smog Stroker | philo | GMC Truck Forum | 2 | 01-24-2007 05:08 PM |
| Building 383 stroker | otrman | Chevy Truck Forum | 3 | 04-13-2006 11:22 PM |
