Old 09-22-2009, 09:58 AM   #1
Crmzendrgone's Avatar
Crmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant future
Question Spindle mounted speed sensor OR Hub mounted
How can you tell what style sensor mount a vehicle has? Do I need to pull the wheel, then what do I look for? Thanks
Old 09-22-2009, 05:11 PM   #2
follow the wire and see where it goes... most of the ones i've done disc are in the bearing, drum in the housing
Old 09-22-2009, 07:06 PM   #3
Ok. I will pull the wheel tomorrow and see what I can see. Thanks
Old 11-23-2009, 06:59 AM   #4
Finally
I finally got some pictures when I did my power steering repair. So which is this spindle mounted??? I am going with it being spindle.
spindle-mounted-speed-sensor-or-hub-mounted-100_3661.jpg  spindle-mounted-speed-sensor-or-hub-mounted-100_3662.jpg  spindle-mounted-speed-sensor-or-hub-mounted-100_3663.jpg
Old 11-23-2009, 10:50 AM   #5
i will go with spindle as well. hub are contained in the assembly and usually not seen. that design on yours would seem to have more flaws than ones inside the hub assembly section. or so it would seem.
Old 11-23-2009, 11:55 AM   #6
Well I guess this is the predecessor to what is out know
Old 11-23-2009, 12:00 PM   #7
This is why I asked all this to begin with cause:
Hello,
The same kit fits both pickup and SUV models. The SUV models do require a rear sway bar link kit in addition to the main suspension kit. Some models do require exhaust modification, which is no big deal and easily addressed. If the vehicle is equipped with the ABS system you do need to identify which style you have. There is a spindle/steering knuckle mounted system and a hub mounted system. Our system doesn’t accommodate the spindle/steering knuckle mounted ABS system. It will work with the hub mounted ABS system only. The only way our kit can be used on the spindle/steering knuckle mounted ABS system is to convert to the hub mounted system, which also requires different CV axles. If you have any questions or need any further information please feel free to e-mail me back, or you can also give us a call toll free at (866) 469-7257.
Thank you for the inquiry.
Matt Yoder
RCD Suspension
1900 Weld Blvd., Ste. #100
El Cajon, CA 92020
PH # (619) 588-4723
info@racecardynamics.com
www.racecardynamics.com
Old 11-23-2009, 01:54 PM   #8
that makes alot of sense. or you could do away with the ABS entirely and drive like people used to. common sense. if the brakes lock up, let out a bit to regain control of your vehicle.
Old 11-23-2009, 02:10 PM   #9
Looks like some grease wouldn't hurt the suspension either
Old 11-23-2009, 03:27 PM   #10
Is that a real posibility cause I would do it. I grew up driving without ABS. 1977 cordoba, 1986 Ponitac Trans Am, 1986 Oldsmobile Cutless Wagon
True other than the joints are all shot!!! the boots are all but gone. Trust me that is on my list to be fixed.
Fuel filter (the kind mounted to frame rail) Stitz Love Chevy Truck Forum 9 09-27-2009 09:48 AM
Location of speed sensor sweetkris0 Chevy Truck Forum 4 08-24-2008 06:17 PM
The "lift bed" Procedure for R&R tank mounted fuel pump? Shox Chevy Truck Forum 4 02-16-2007 11:01 AM
ABS and Speed Sensor parshdude Dodge Truck Forum 1 10-04-2006 05:07 AM
Furukawa Eyes Higher Overseas Sales Of Truck-Mounted Cranes (Asia Pulse via Yahoo! Australia & NZ News) trucknews Truck News (headlines) 0 11-02-2004 02:30 AM
