| Full Member Join Date: Sep 2009
| what tranny do I have? Is the rear a limited slip or locker? I just bought a used 2001 2500hd 2wd ext cab. It has the 6.0. How do I tell which automatic tranny is has? I don't see any Allison emblems on the door, so I'm ruling that one out...I guess. Would the rear end be a locking rear or a limited slip? Is there a website where I can run the serial number and find out more about whats in this truck? THANKS !! |
| ask the dealer to run it for you and check for recalls and updates, it should help
| On the rearend take off from a dead stop in water or dry pavement if your GM truck goes sideways it's a posi. 1993-1997 GM 4L60E &1997-2005 GM 4L60E C5 CorvetteHP242700 2 HP242800 2,8 HP243107 2,18 HP242962 3,9 HP243105 2 HP243106 2,15 HP242963 3,9 1998-up GM 4L60E F-bodyLS1/LS2 applications; 1999-up GM 4L60E/4L65E trucks w/ 4.8, 5.3, 6.0 enginesHP242935 11 ,17 HP242938 11 HP242931 10,11 1991-99 GM 4L80E |
| Senior Member Join Date: Aug 2009 Location: Northern California
| You should be able to get the RPO , Regular Production Codes, from the glove box lid, unless they are in a different place on your yr truck, then you can decode them on GMs GMC website. Hope this helps.CM65 |
| Trans is likely to be a 4L80-E. The Allison was in the Duramax and 8.1 big block only. The RPO code may still be G80 for that year. If it is, likley to be the Eaton Gov Lock. Its Ok for pulling a boat up a wet ramp but its not a wonderful unit if that is what it has. If its not, and you have an open diff, you can put a Richmond Lock Right in it yourself without have to reset up the gears. That would be my preferance anyway.
| | #6 | |
Hmmm... maybe it's small enough to attach? Nope... it's about a meg and a half (188 pages) and the system only allows me 150kb Okay, I stuck it on my own server. You can get it at this link: http://spwaw.com/bwb/GM-RPO-Master-List.pdf
| So I wonder if you know someone who will let you post it on their site and link to it. |
| | #8 | |
| How did you slide that past me ? I usually read all the words, even the big ones. |
| | #10 | |
__________________ If the guys who design 'em had to take one home, use it every day for 2 years, and do all the maint and repairs themselves, cars would have a button on the dash to change the oil, filters & plugs. Last edited by BernieB; 09-24-2009 at 11:33 PM. | |
| Tags |
| 2001, 2500hd, rpo codes, transmission |
| Limited Slip Questions | blackhawk17 | GMC Truck Forum | 5 | 07-26-2008 01:00 PM |
| Limited Slip or Posi? | WisconsinHick | Chevy Truck Forum | 18 | 04-03-2008 05:35 PM |
| Limited Slip Diff. | ct. cowboy | Chevy Truck Forum | 4 | 03-31-2008 06:10 PM |
| Limited slip rear axle problem....... | truckman | Chevy Truck Forum | 7 | 03-24-2008 10:54 AM |
| 10 bolt rear diff with 3:73 limited slip carrier | chevyguy | Truck Classifieds | 13 | 06-16-2006 10:21 PM |
