Old 09-27-2009, 07:53 AM   #1
wcamarano is on a distinguished road
AC fan blowing slower than ever
Just replaced altenator and then i lost dash lights and power to ac blower/fan controls after checking fuses and fusable links ,removed and reversed position of those 2 30 amp circuit breakers and now have power but,, highest fan level is like the lowest level before altenator switch,,,anyone have a clue what's wrong ???? Thanks
wcamarano is offline   Reply With Quote
Old 09-27-2009, 09:12 AM   #2
BernieB's Avatar
Sounds like your new alternator is no good, or you didn't hook up the field wire. Did you buy new or a rebuild?
If you have a meter check and see what kind of voltage you have at the battery with the engine running. Should be between 12 and 14, with 13.8 being ideal.
Old 09-27-2009, 09:55 AM   #3
Yea i did that already ,,got 13.7 running and 12.5 not running at battery,even went bought new breaker but does nothing...
Old 09-27-2009, 12:45 PM   #4
crabtruck's Avatar
Blower slow at hi-spd sounds like the batt voltage isn't getting there.
That could be caused by poor connections on ground side
just as easily as batt side. With the recent work, check those grounds.
May want to check voltage at blower itself and resistor for ref.
What truck is this ?
Old 09-27-2009, 01:37 PM   #5
what do you have with all the accesories on? should hold 13.6v or better then.
(lights,blower,defogger,etc)
Old 09-28-2009, 08:07 AM   #6
Now this has happen to me before I fix something and something else whet out maybe one of your speed relays under the dash messed up.
Old 10-17-2009, 07:26 AM   #7
Help
It's a 1991 gmc 2500 extra cab longbed ...where would i check resistor and what should resistence be ? and where to check blower in eng.compartment ?
Old 10-17-2009, 07:46 AM   #8
Ninja_Lawn_Guy's Avatar
Ninja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the roughNinja_Lawn_Guy is a jewel in the rough
hahahahahaha
Ninja_Lawn_Guy is offline   Reply With Quote
Old 10-17-2009, 08:20 AM   #9
Originally Posted by Ninja_Lawn_Guy View Post
hahahahahaha
What the F**# ...Have you started drinking already !
Old 10-17-2009, 03:17 PM   #10
chevy gmc heat ac blower issues...do I hear 6?
<---I was drinkin early...so busted
Heater not blowing hot Dodge01 Dodge Truck Forum 5 10-07-2009 08:09 AM
Fuse keeps blowing salsterboy Chevy Truck Forum 5 09-11-2009 12:24 AM
4x4 Fuse blowing 5150gixxer Chevy Truck Forum 6 04-18-2009 04:33 AM
keeps blowing seal tcbandit Nissan Truck Forum 2 01-22-2008 03:07 PM
