| | #21 |
| Full Member Join Date: Oct 2009
| well well i turn the truck over and no gas leaks out the fuel filter.. i got the filter undone and nothing comes out.. i figured it was bad.. and i cant hear the pump ethier |
| | #22 | ||
Welcome to the forum snider, late tho I say it. This is a great example of why all the info you can kick in at the beginning of the (single) thread is important. Find the sender wire at tank or the ground wire and jump it to ground. If gauge reads right, then stop slandering your pump until you are sure it's really connected. Shared ground. | ||
| | #23 |
| fuel pump i replaced my fuel pump in my 1989 gmc 5.7 v8 ext cab. i can hear the pump now.. and i dont think its getting gas still. i did not replace fuel filter. shoul di replaced filter to and see if thats the problem? is ther a way i can test to see if the filter is bad |
| | #24 |
| Full Member Join Date: Jan 2009 Location: greenville,tx
| undo the outgoing side of the filter and turn the key see if fuel is going through like it should. |
| | #25 |
| if you can afford a pump, you can certainly but a filter. if you dont know the last time you replaced the filter, then do it now. dont even bother in testing it. why do you "think" that it is not getting gas?? |
| | #26 |
| Did you replace the pump originally cause you were not getting fuel or you knew it was bad?
| | #27 | |
Good luck! GMC | |
