Old 10-15-2009, 06:29 PM   #1
Transmission Biting the big one ?
This morning pulling away from stop sign,my 95 K1500 5.7 gave out a nasty slipping gear sound. Let up it quit shortly after giving it the gas again the same thing
happened.Sounded a little like grinding the gears on a stick. These transmissions have problems with sprag gears?
What kind of a job is it taking the trans out of a 4X4 ?
Scav.
Old 10-24-2009, 02:53 PM   #2
A question about this. I hear a drum on these breaks. Is this true and is it common? It gives me a ratchet sound in first and second.Never in third or above. I want to be sure about this before I change transmissions or have it rebuilt. Also if I have it rebuilt , is there an aftermarket drum they put in so it don't happen again?Truck has 234,000 on it engine trans is supposed to have about 140,000 on it according to the guy I bought it from.
Scav.
Old 10-24-2009, 04:48 PM   #3
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
the drum you are refering to is called the sun shell and yes the heavy duty one is called THE BEAST three times stronger hope this helps
PAPA BEAR is offline   Reply With Quote
Old 10-24-2009, 09:35 PM   #4
For sure get THE BEAST. I'm sorry how you feel my trans already shelled out once and now with this one reverse has a slight delay im going to try some Lucas it's been doing it for years but I don't drive my truck much. Remember that year of trans is a odd ball year only that year of trans will fit your truck also while your there have your rear main seal put on even check the trans mount.
Old 10-24-2009, 10:51 PM   #5
Thank you , the information I was looking for.I now know I don't even want to mess with a rebuilt, have this one rebuilt.
Scav.
which transmission? asthesun Chevy Truck Forum 19 10-05-2009 07:50 PM
Transmission.............. Runn Chevy Truck Forum 7 09-14-2009 06:48 AM
Bad Transmission Diesel_Fan Chevy Truck Forum 12 12-14-2007 09:45 PM
transmission 87sierraclassic GMC Truck Forum 13 09-11-2006 08:47 PM
Transmission ? skully Chevy Truck Forum 2 01-28-2006 10:33 AM
