Old 10-17-2009, 04:39 PM   #1
Crmzendrgone's Avatar
Question 700r4 Transmision Torque Converter Lockup
How can you tell if the transmission's Torque converter is locking up or not. Is there a way to test if it is or not.
Old 10-17-2009, 09:31 PM   #2
silverhairdeere's Avatar
yes it does have , you should have 12 volts at the pressure switch
Wiring a Lockup-Converter Pressure Switch
shd
Old 10-18-2009, 08:51 PM   #3
Ok I am confused. Is there a switch already or is that website selling a replacement part.
I guess I thought you can tell if it locks up by RPMs and if mine has a switch where would that be located at? Thanks.
Old 10-18-2009, 09:50 PM   #4
there is a switch already present , all you need to do is wire it up .
shs
Old 10-19-2009, 10:57 AM   #5
You could try this. Hold a dead steady speed of say 45mph and note the reading on the tach. Keeping the speed steady press the brake pedal with your left foot, enough to turn the brake lights on but not enough to apply the brakes. If the tach jumps a few hundred revs then the lockup is working, if no change in tach reading then the lockup is not working.
Old 10-19-2009, 11:22 AM   #6
hotrodpc's Avatar
What Case said up there. ^^^
But if pay real close to attention, you might even notice it. It would be like shifting into 5th gear.
Old 10-21-2009, 10:11 AM   #7
Ok I tried that way of pressing the brake pedal after getting to a cruising speed of 45 just to trip the switch but I saw no noticeable change in RPMs how much does it jump couple hundred RPMs? I know about 3+years ago after I installed my tach. I could cruise at 65 MPH at 1800 RPM now I am at 65/2000. Does that sound about right if it is locking up 65/1800?
Old 10-21-2009, 01:14 PM   #8
trust me on this , if your converter wasn't locking up your trans would toast it self , anything can make a difference in rpm from wind to low air in your tires .
shd
Old 10-21-2009, 01:51 PM   #9
The higher the speed you do the test the more the revs should jump. Try it again at 50mph or 55 and the tach should jump a couple of hundred revs if the lockup is working. Or to put it another way the more accel pedal you will have to give it to maintain the same speed.
Old 10-21-2009, 02:09 PM   #10
hotrodpc's Avatar
I am curious what you are reffering to SHD. I think you are talking about something I am not aware of. There are situation where you TC will not lock up but your trans is fine. You could lose voltage to your TC lock up switch, the switch could fail etc etc. If his test did not work, and he used to cruise at 1800 before and now its 2000. I am thinking he is not locking up anymore. But why would that toast the converter?
What effect does a Stall Torque converter have? Sneakysportsman Chevy Truck Forum 12 06-10-2009 05:30 AM
torque converter AndyinCt. Chevy Truck Forum 10 01-02-2009 10:03 AM
Torque converter removal steven1213 Chevy Truck Forum 3 03-01-2008 03:53 PM
Which torque converter should I use chuckphillips Chevy Truck Forum 5 12-29-2007 07:29 PM
Torque Converter for Towing mater 4x4 trucks / off road 4 11-30-2007 09:42 AM
